10-04-2014, 04:48 PM | #1 |
Rep 562
Is 9.5 Front and 11.0 Rear too big of a spread?
So, I just ordered some Forgestar F14 SDC in 9.5/11.0 and now I am not sure I should have made that 1.5" spread....
Some people go with 10" in the front but I have read that it does protrude outside the fender a bit in the SDC. I cannot find a definitive answer on front tire size to match a 295/30/19 rear on an 11, and 9.5 front, 265/30 or 275/30? I plan to go with the Hankooks any input will be greatly appreciated... |
10-05-2014, 09:46 AM | #4 |
11817
Rep 23,187
10-05-2014, 10:02 AM | #5 |
Rep 979
i have 9.5" front and 11" rear and it is fine depending on your offsets.
But i run 255 front and 295 rears
2011 E92 M3 | JEREZ BLACK | EXTENDED BAMBOO NOVILLO | EXECUTIVE PKG | M-DRIVE | EDC | M-DCT
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts |
10-05-2014, 10:02 AM | #6 |
Rep 5,541
What F offset were you using? With -2.5 deg of F camber I can run a 9.5et17 with a 275 tire without rubbing or making contacting with the strut body/spring perch (aftermarket).
10-05-2014, 10:53 AM | #8 | |
Rep 2,940
I would go: 19x9.5 ET25 with 255/35/19 front & 19x11 ET30 with 295/30/19 rear.
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner |
10-05-2014, 10:55 AM | #9 |
Rep 2,940
255/35 may rub if the offset is too aggressive
10-05-2014, 11:22 AM | #10 |
11817
Rep 23,187
10-05-2014, 11:36 AM | #11 |
Rep 5,541
10-05-2014, 01:04 PM | #12 |
Rep 673
Drives: Adidas and Puma
I run 275/35 - 295/35 on 18x10/18x11 while lowered on JRZ. The only rubbing I have in the front is slightly on the inside of the rear wheel well, and that's only at full lock. The rear is set pretty stiff, only rubs if car encounters a serious bump/dip.
Highway Star Garage / Ruined Luxury Auto
InstaGram: Ruinedluxury_vybz NA1 NSX - Storage 2nd Gen Taco - Daily |
10-05-2014, 02:07 PM | #13 |
11817
Rep 23,187
10-05-2014, 03:11 PM | #14 |
Finally done modding...until the next mod.
10
Rep 130
On my E90 I run a 19x9.5 with 275/30 and 19x11 with 295/30. On Dinan suspension. Zero issues, love the setup. Only rubs slightly in the front at full lock. I've seen E92s run this similar setup here on the forum as well.
'10 6MT ZCP E90 M3 - Brembo: GT BBK(front/rear) / Dinan: Mid-pipe & Race SW, Pulley Kit, Stage 2 Suspension, Strut Braces, Rear Toe Links / AFE: Stage 2 Intake / BMW Performance: V2 Electronic Steering Wheel (w/ AutoCarbon CF Trim), CF Mirror Caps, CF Spoiler, CF Interior Trim / LTMW: 1M M3 Front Bumper w/ Slek CF Lip / AEPX: ARC-8s / Akrapovic: Rear Exhaust / Arkym: CF Rear Diffuser / Vinyl Styles: partial matte grey wrap / etc...
10-05-2014, 04:39 PM | #15 |
White Shark
88
Rep 919
i run 255/35 and 295/30 (hankook v12) with my forgestars while being lowered on coils. zero issues and no rubbing
ESS | Challenge x-pipe | Akrapovic | Stoptech BBK (380/355) |Ohlins R&T | Dinan | Vorsteiner | Downforce USA | Varis Diffuser | Gintani | UUC | BMW Performance | Macht Schnell | Forgestar F14's SDC 19x9.5F 19x11R | 255.35 295.30
10-05-2014, 05:15 PM | #16 | |
Rep 6,734
I have ran 275's in the front on many wheel sets. You need between -1.5 to -2.0 camber in the front. I would not run a 255/295 stagger unless you want more understeer for some reason.
'23 X7
10-05-2014, 06:35 PM | #17 | |
Rep 562
Thanks for all the input so far everyone, you all have put my mind at ease... |
10-05-2014, 06:41 PM | #18 | |
10
Rep 130
10-05-2014, 07:00 PM | #19 |
Rep 562
10-05-2014, 07:35 PM | #20 |
Rep 5,541
Why does wheel diameter matter? The OD of wider than stock tires, 18" or 19", should be close to the OD of stock width tires. The OD of a 275/30-19 and 275/35-18 tire are the same so the clearances will be the same as long as both wheels are 9.5et22.
10-05-2014, 07:57 PM | #21 | |
11817
Rep 23,187
I'm in the process of making 285-30-18/280-650-18 square fit my e46. Last edited by 1MOREMOD; 10-06-2014 at 12:33 AM.. |
10-05-2014, 10:25 PM | #22 |
10
Rep 130
Dinan suspension lowers it 1/2" front and rear. I'm running Michelin Pilot Super Sports. Happy with the setup, here's how it looks.
