05-21-2016, 11:54 PM | #1 |
Rep 1,236
Locking Lug Nuts
What's a good brand for locking wheel nuts? I know wheel locks only slow down real thieves, but I rather have the little protection than none.
I've been looking for some good locking extended and opened ended lugs in red, but can't find anything under $150. I know I shouldn't be cheap on something as important as lugs, but when there are sets on ebay for $40 it's kind of hard justifying paying $200+ for nuts. |
05-22-2016, 11:55 AM | #4 |
Rep 6,727
I've had two sets of Project Kics R40 lugs and I liked them so far. The key is a bit uninspiring but does the job. I like how the interface doesn't mar the wheels at the lug points.
If you see some sets on eBay for $40, get two for that price and double up the locks. |
05-22-2016, 03:06 PM | #6 | |
Rep 1,236
05-22-2016, 11:29 PM | #7 | |
I got lei'd
845
Rep 7,594
05-23-2016, 01:12 AM | #8 | |
Rep 6,727
You can use a Chromoly socket (the shiny ones) if you aren't using an impact wrench. Impact sockets will be black. Let me know if you still need a picture after that |
05-23-2016, 02:01 AM | #9 | |
I got lei'd
845
Rep 7,594
05-23-2016, 02:12 AM | #10 | |
Rep 6,727
You should be using a 1/2" drive wrench, extension, and socket The Kic socket goes in to the 17mm socket... unless I'm missing something... Here's an example Last edited by BzsBimmer; 05-23-2016 at 02:21 AM.. |
05-23-2016, 07:46 PM | #11 |
I got lei'd
845
Rep 7,594
This is what I have
05-23-2016, 07:56 PM | #13 |
Rep 6,727
The black piece is not a true socket. It doesn't have the square drive on the end.
The torque driver male side needs a female to mate with. You have an adapter (not needed) that looks like it steps down from 1/2" to 3/8" |
05-23-2016, 08:34 PM | #14 | |
I got lei'd
845
Rep 7,594
the 1/2" to 3/8" adapter is what i use for the regular sockets we're used too |
05-23-2016, 10:52 PM | #15 |
Rep 1,405
On this very day, I got rid of all my locking lug nuts and replaced them with standard lug nuts.
The reason I did it was because I tried taking off a wheel (with a screw in the tire) and found that the key would not work. The tire shop guy got it off and I told him to get rid of the other three. I'm not interested in having a slow leaking tire (or a flat) and not being able to take it off and bring it somewhere to get fixed. Speaking of tires, the next time I have to change tires, I'm going to look hard at installing run flats on my E93. This thing with injecting some kind of goo into a flat tire via the valve stem sounds real messy to me. |
05-23-2016, 10:53 PM | #16 |
Rep 6,727
Ok not sure where we're losing things in translation here but I'll give it one more go.
The torque wrench should be a 1/2" drive You will need a 1/2" drive 3" extension You will need a 1/2" drive 17mm socket You will need your Kics keyed socket meaning that you have to spin it around on the lug until it engages. The splines match up only one way. The 17mm socket goes over the hex end of the shiny Kics socket/key. Amazon.com: TEKTON 47772 1/2-Inch Drive by 17 mm Shallow ... http://goo.gl/UlfgP1 This is an example of the socket I'm referring to. I honestly suggest that if you can't figure out what socket to use, you may want to go to a specialist. Last edited by BzsBimmer; 05-23-2016 at 11:06 PM.. |
05-24-2016, 01:41 AM | #18 |
Rep 479
Yep I bought them
I did have a set bull lock nuts I bought from evasive. Those were pretty good. http://www.evasivemotorsports.com/mm...tegory_Code=L1 |
05-24-2016, 02:31 AM | #19 | ||
I got lei'd
845
Rep 7,594
05-24-2016, 09:00 AM | #20 |
Stop the hate, get a V8
3851
Rep 8,625
Dumb question, what's wrong with the OEM locks? No lock is 100% theft-proof, it's just there to deter the casuals.
Past: 2011.5 M3 sedan ZCP |
05-24-2016, 09:18 AM | #21 |
Rep 1,588
I run Kics R40 and have been really happy with them. I swap wheels about every two weekends for autocross and they make the job simple. Locks seem to work well enough, they are enough to keep the honest thief away.
2012 E92 M3
Instagram Turbo__Joe |
05-24-2016, 09:24 AM | #22 |
Rep 6,727
