05-05-2020, 10:14 PM | #1 |
Rep 207
Need help with tire sizes!
What tire sizes are you guys running on 19x9.5 et22 and 19x10.5 et22? Was originally doing 265/30 and 285/30 but 285/30 is not offered in PS4S. Anyone rubbing on 275F and 295R with these offsets?
My wheels are Apex EC-7 in those offsets. Based on their guide I should run 265/30 and 285/30 for a flush fitment. Problem is 285/30 is not available in PS4S tires, only PSS. Should I do 295/30 or just run continental? As for the front, is it possible to fit 275/30 on et22?
05-05-2020, 10:38 PM | #2 |
Rep 1,055
I currently run the second setup in the Apex article. 295 PSS in the back were too close to the fender for comfort so I raised the rear a bit. Some manufacturers run more narrow so you may be fine with other than PSS if you find one that runs more narrow. I really came to appreciate the tire specs that tirerack lists when researching sizes.
275s up front rub the liner on lock. |
05-05-2020, 10:40 PM | #3 | |
Rep 207
05-08-2020, 11:44 AM | #4 |
Rep 5,483
I use 275/30-19 PS4S ET23 Style 220 rear wheels square for my pothole season setup
It fits great. Pretty much identical fender liner clearance to my 275/35-18 contis on 18x10 ET25, because the 19" michelin setup has a more square sidewall profile
05-08-2020, 11:46 AM | #5 |
Rep 207
I ended up going with 19x10 et25 square setup. Thinking of doing 265/30F and 285/30R for that staggered look. What do you think
05-08-2020, 11:47 AM | #6 |
Rep 5,483
I think you'll wish you could rotate - I'd use a 275 and if you want it to fill out better in back, use a 5 or 12mm spacer
ApexWheels1426.50 |
