GetBMWParts
      11-27-2016, 05:00 PM   #1
mdm9
mdm9's Avatar
Drives: 2009 Interlagos Blue E90 M3
2009 M3  [0.00]
Strange dark film inside oil fill hole
I recently changed the oil, I put in LiquiMoly GT1 10w-60. Then today, I went to top off the oil, opened the oil fill cap and saw this. It seems like there is a dark film coating everything. Pics attached.
I'm at just over 80k and my car is an 09 e90. The car in the oil changing tutorial I followed didn't seem to have this, at least as far as I could tell from the photos.
Any ideas what this is?
All help appreciated!
      11-27-2016, 05:02 PM   #2
mdm9
mdm9's Avatar
2009 M3  [0.00]
Pics
      11-27-2016, 05:19 PM   #3
dparm
dparm's Avatar
Drives: C7 Corvette Grand Sport
If you reach in there with a Q-Tip or something similar, can you wipe it off? What's the consistency, smell, etc. like? If you pull the filter, does it have the same liquid all over it too? What's the car's service history like?
The dark film could just be varnish, which is normal.
Now: 2017 Corvette Grand Sport
Past: 2011.5 M3 sedan ZCP
      11-27-2016, 05:37 PM   #4
mdm9
mdm9's Avatar
2009 M3  [0.00]
Thank you for your quick reply.
I scraped it HARD with a q tip and some of it came off as you can see, but it didn't come off very easily. It is kind of gunky or carbonlike in consistency. Nothing to note in terms of smell, but I have a horrible sense of smell coupled with a lack of mechanical experience so I can't identify anything in particular.
Car has been maintained regularly, but has not had a rod bearing service or anything else significant to note in its history. Never tracked, although driven hard and over long distances.
      11-27-2016, 05:39 PM   #5
mdm9
mdm9's Avatar
2009 M3  [0.00]
Circled
      11-28-2016, 09:31 AM   #6
dparm
dparm's Avatar
That sounds like varnish. Are you saying this was never there before, or are you admitting you might just be noticing it for the first time now?
      11-28-2016, 09:37 AM   #7
mdm9
mdm9's Avatar
2009 M3  [0.00]
It is possible I am noticing it for the first time.
I found this thread where it looks nearly identical to mine.
http://www.m3post.com/forums/showthread.php?t=935340
      11-30-2016, 05:49 AM   #8
Helmsman
Helmsman's Avatar
Sweden
1680
Drives: 2011 E90 M3 ZCP
MDM9, how often do you change oil mate, could it be "gunk" from a bit too long in between?
The oil do eventually go gunky...https://www.google.se/search?q=oil+g...IBigB&dpr=1.25
      11-30-2016, 09:04 AM   #9
doogee
doogee's Avatar
Drives: '08 M3, '97 328is
Looks like rod bearing fragments to me
Kidding. Someone didn't change the oil enough. Don't worry about it.
      11-30-2016, 10:56 AM   #10
dparm
dparm's Avatar
Those photos are from cars that have known sludge problems (VW 1.8, for example) or cars that went 30k without an oil change. I doubt OP has that problem even if he went the full 24 mo/15k for his changes.
      11-30-2016, 02:23 PM   #11
Helmsman
Helmsman's Avatar
Sweden
1680
Judging from some bottom end pictures from engines with claimed 15k intervall, looking pretty damn dirty and even gunky, wouldn't be surprised if that stuff eventually find its way around. Curious to hear what intervall OPs car have been running on. Or what the alternativ reason possibly could be.
Search this Thread:
Advanced Search
