      10-08-2020, 01:31 AM   #1
kyippee
kyippee's Avatar
Drives: 2011 E92 M3 ZCP
SPL front arms - headlight adjustment rod, is it really needed?
Hey Everyone,
I'm looking at getting SPL arms up front and Bimmerworld has a kit that saves a bit of money vs. buying the 3 pairs of arms separately:
https://www.bimmerworld.com/BimmerWo...onversion.html
I'm confused about how some of the individual product pages talk about headlight levelling arms being missing. Do I really need them? Will there be some error codes or headlight levelling problems? I'm o.k. with the car not dynamically moving headlights up or down, as I believe I can just adjust manually under the hood.
Lower wishbones have a street version that include the rod. I assume race version (without rod) is included in the kit and will call BW to confirm: https://www.bimmerworld.com/SPL-Race...-Race-E9X.html
Tie rod ends include the rod:
https://www.bimmerworld.com/SPL-Race...s-E82-E9X.html
Upper control arms don't have the rod, don't see a street version:
      10-08-2020, 08:02 AM   #2
slicer
slicer's Avatar
Drives: '13 E92 M3 - '20 X3MC
Get the street version of the front LCA (lower wishbones). Everything other than the headlight level sensor mount is the same.
Not sure what you are referring to when you say the "rod" associated with the other parts. The headlight adjuster only applies to the main LCA. All other parts only have one version.
'13 E92 M3 - Ohlins TTX, SPL Susp Arms, AP Racing BBK, Akrapovic GT4, CSF Cooling, VPhreaks Bat, OE M3 GTS - Lip/RSD/Cage, M240ir Wing, Varis Diffuser, Karbonius Airbox, MFactory DS, M24 Door Cards, KMP Wheel, Sparco Seats w/BK Mounts, BBS E88, BBS RIA, 3200 lbs
'20 X3M Comp - BBS LM (21"), BBS CIR (20"), H&R Springs, Akrapovic EVO
INSTAGRAM - @Slicer_M
kyippee822.50
      10-08-2020, 01:08 PM   #3
kyippee
kyippee's Avatar
Thanks slicer ! I am definitely not knowledgeable about these parts.
The part that confuses me on the upper control arms is this part: "Designed for track/racing use only. There is no mounting position for a headlight adjusting rod." Does that mean the stock upper arms have a position for it and this SPL part doesn't? Seems weird foes they to write that in.
I also got confused with the tension arm monoballs. I don't see an SPL front tension arm. Is it correct that I'd still need to buy a tension arm w/monoballs like the GAS brand one? (I am replacing)
      10-08-2020, 01:26 PM   #4
//steve\\
//steve\\'s Avatar
Drives: 2012 E92 M3
No, there is a SPL front tension arm. It's totally straight unlike the OE part that's all twisted. In the bundle you linked it's the skinny long arm.
Steve::::2012 AW E92::::IG - @sjs0433
kyippee822.50
      10-08-2020, 01:33 PM   #5
kyippee
kyippee's Avatar
Thanks Steve! The site must be confusing me or I'm just clearly rushing things while working. The name changes between bimmerworld and SPL site.
I confirmed over the phone w/bimmerworld that it is indeed one part that needs the headlight rod. (lower wishbone - race version linked here https://www.bimmerworld.com/SPL-Race...-Race-E9X.html)
It would need to be ordered in the street version to have the rod. Swapped out race for street version during my call to order.
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
