      09-20-2020, 02:48 PM   #1
bvrider1
Drives: e90 m3
Educate me on this tire wear
So these are older pilot super sports. I am new to track days so I am trying to learn as much as I can.
Feedback on the tire wear is appreciated!
      09-20-2020, 02:50 PM   #2
ThunderMoose
Looks good
      09-20-2020, 02:55 PM   #3
bvrider1
Drives: e90 m3
I was concerned I was running too low tire pressure. Hot tire pressure was at 31 psi.
      09-20-2020, 04:32 PM   #4
Richbot
Drives: Jerez Black E90
Normal. Probably going to need some mroe pressure to keep the outside edges from dying soon
      09-21-2020, 08:35 AM   #5
dparm
Stop the hate, get a V8
dparm's Avatar
Drives: C7 Corvette Grand Sport
Pretty standard wear for a tire like that. Some rice-graining and "material movement" is normal.
The tiny chunking is somewhat symptomatic of overheating or overdriving, but not a ton you can do except maybe be more aware of your slip angles and monitor pressures carefully.
Now: 2017 Corvette Grand Sport
Past: 2011.5 M3 sedan ZCP
      09-21-2020, 12:23 PM   #6
bvrider1
Drives: e90 m3
Thank you for that explanation!
      09-21-2020, 12:43 PM   #7
dparm
dparm's Avatar
How many track days or minutes are on those? What track was it and which direction did you run them? Did you rotate/flip at any point?
      09-21-2020, 09:32 PM   #8
bvrider1
Drives: e90 m3
I have a square set of wheels now which will be my dedicated track set up.
I don't think it is worth anymore time to keep on using this existing staggered setup
      09-22-2020, 08:46 AM   #9
dparm
dparm's Avatar
For 5 track days I would say those look really good.
tsk941114.00
bvrider1238.00
      09-26-2020, 09:33 AM   #10
Whit45
Drives: '08 E90 335i/'10 E92 M3/'13 Is
I think 31psi hot is a little low. You might want to try 35-36 hot , and if you feel you are having some understeer, reduce the rear by 1-2psi.
bvrider1238.00
Search this Thread:
Advanced Search
Copyright ©2000 - 2021, vBulletin Solutions Inc.
