07-29-2020, 01:03 PM | #1 |
Rep 108
Ferodo DS2500, DS3000 or DSUNO?
Quite hard track days and some street. What do you recommend? M3 E92, M4 F9x brake upgrade.
Ferodo DS2500, DS3000 or DSUNO? Pls Ferodo only.
M3 E92 ZCP LCI
07-29-2020, 02:30 PM | #2 |
I got lei'd
844
Rep 7,593
interested too, not for track use though
Expressivedrives249.00 |
07-29-2020, 06:56 PM | #3 |
Rep 5,506
DS2500 will not hold up to track use. They melt and coat the rotors with pad deposits. Otherwise good street pad.
Auto Detailing Enthusiast!
07-30-2020, 05:57 AM | #4 |
BMWCCA Member
125
Rep 98
Drives: 1997 M3 Sedan
I use Ferodo DS2500s on track and street.
However, they will last me a maximum of 3 track days (5-6 20 minute sessions) at Grattan Raceway for example. The DS 1.11 pad will last SIGNIFICANTLY longer at the cost of quite a bit of noise being generated by the brakes. I hope this is helpful.
[E36]1997 BMW M3 Sedan, 5 Speed
[E92]2011 BMW M3 Coupe, DCT |
07-30-2020, 04:32 PM | #5 |
Rep 305
I've got a set of 2500's front and rear and one track weekend on them and maybe 200 street/highway miles getting to/from track. I pulled them to swap rear rotors this week and can attest, they are noticeably worn. If I stuck with this combo I might get 2 more weekends out of them. That's not to say they don't work well. After a quick bedding session (essex style) they were nearly silent on the street, maybe a light squeal every couple of days but nothing that would draw attention (I rarely have any sounds coming through my speakers so Im able to hear all the little noises this car tends to make).
Do they work on track? Sure I was at Sebring where the straights can get pretty quick and with fresh Endless fluid and brass caliper pin bushings I never felt fade. The pedal response at the end of a 30 min session was the same as the first few min. HOWEVER, I don't want to eat through pads this often and I do think there is more bite to be had so I'm moving to a front biased set up of DS.UNO in the front and 2500's in the back. This is a total compromise move and I get that. PROS: 1) Since it is common for many people to run front only BBK's on this platform with no complaints I can assume moving to higher friction front pad is of no detriment to me on stock clampers. 2) I only have to swap one axle worth of pads on track day. Drive to/from track with same set of rear 2500's. Swap the front 2500's the night I arrive at the track. 3) I only have to buy one axle worth of expensive pads. 2500's are half the cost of 1.11 and UNO. CONS: 1) I have to change pads at the track (front only though) 2) I am spending twice as much money on the front axle for pads, in exchange for more stopping power. This isn't a con, it's just the cost of doing business. Obviously you know that sticking with Ferodo pads for both track and street means easier swapping due to similar compounds. |
Expressivedrives249.00 lowkey_domm62.00 |
07-30-2020, 05:11 PM | #6 |
Rep 12,726
Ds2500 for the street, dsUNO for the track. Swap them.
Expressivedrives249.00 Visceral363.00 |
07-31-2020, 01:36 AM | #7 |
Rep 108
Hi, thanks for your input.
Are DSUNO's impossible noisy on the street or missing braking power when cold?
M3 E92 ZCP LCI
07-31-2020, 04:13 AM | #8 |
Rep 12,726
Both, but mostly noise. i was told by an expert, and i found this to be true with personal experience- swapping between ferodo pads doesn't require any bedding after switching with other ferodo brand pads. its a couple bolts, just swap and you'll be happier.
07-31-2020, 06:08 AM | #9 |
Rep 1,027
This tends to be pretty true when you stay within the same brand of pads from what I've also heard.
Steve::::2012 AW E92::::IG - @sjs0433
07-31-2020, 11:24 AM | #10 |
Rep 5,506
Question for the original poster, you have what looks like F80 calipers on your M3? How does that fit? Does someone make a kit for that?
08-01-2020, 05:11 AM | #11 | |
Rep 108
Details: https://www.expressivedrives.com/blog/f8x-brakes-to-f9x It's a very economic way to go to bigger and more advanced brakes on E92, as M4 sets are sold (used) on eBay. I'm very pleased with these bigger Brembos. Earlier I toasted set of front pads (DS2500) in one long track day, now I dont have this risk.
M3 E92 ZCP LCI
Z K1888.50 |
08-06-2020, 01:16 PM | #12 |
Rep 842
I just posted something about this topic over in the M2 forum...everything below applies with the e90 chassis. I wrote:
For the M2, the DS2500 would be marginal on the front of the car in some circumstances. As noted, every driver, track, and car is different. As such, what works for one person's situation isn't necessarily going to be ideal for another's. On one hand you may have a stock M2 on street tires, on Roebling Road, being driven by someone who is easy on the brakes. On the other hand you have a driver who is tough on brakes, driving Road America on Hoosier slicks, and he has added 50 HP. The difference between the brake demands in these two scenarios is tremendous. As an overarching baseline recommendation, I'd consider the DS2500 a good street, AutoX, and very light track duty pad for the front of an M2 and M2 Competition. It should work well on the front and rear if you're on street tires, the car isn't juiced up with extra HP, the track is fairly easy on brakes, and the driver is average on brakes. As a rear pad, the DS2500 is going to be fine with no issues under just about any conditions. You'll never get them hot enough on the rear of an M2 to cause any problems, regardless of what track you're on, tire choice, etc. Some of our brake kit customers leave the DS2500 in the rear calipers all the time, so they don't have to swap them out when going from track to street and back. The only issue with this strategy is that the DS2500 is lower mu than the DS1.11 or DS3.12. Running the lower mu DS2500 in the rear effectively increases the amount of work your front brakes need to do. That creates more heat in front brakes. That may not be a problem, or it may be...depends on the situation. One would really have to experiment to be sure. The DS2500 does have a very high max operating temperature though. It's extremely rare that anyone will fade it. What happens more often, as others in this thread have noted, is that it starts to burn up very rapidly when it gets ridiculously hot. Fortunately, that is a nice/gentle failure mode, and doesn't end badly (vs. the pad giving up all mu and you not having a brake pedal when you step on it...which is not a gentle failure mode!). If you are running race tires, have extra HP, are particularly hard on brakes, or you're driving a tough braking track, I'd suggest the Ferodo DS1.11 or DS3.12. They can both handle any amount of heat thrown at them, will never fade, etc. The beauty of the Ferodo DS compounds is that you can swap them around on the same discs without having to re-bed them. For example, you run the DS2500 on street/autoX, then the DS1.11 at the track. If you were using pads from multiple manufacturers, the smart play would be to scrape the discs clean to get all the pad material off their face prior to bedding in the other pad compound. Otherwise you'd risk cross-contamination of the pads on the disc face, which leads to judder and vibration. With the Ferodo line, you don't have to worry about that. You just lay them down on top of each other and they play nice. |
lowkey_domm62.00 |
08-06-2020, 04:35 PM | #13 |
Rep 285
Thought it was pretty funny, as I was reading this I got a knock on the door from UPS! Look what I got
IG: lowkey_domm
DerEisbaer100.00 |
08-07-2020, 07:10 AM | #14 |
Rep 842
08-08-2020, 11:21 AM | #15 |
Rep 108
DS2500?
M3 E92 ZCP LCI
08-10-2020, 10:31 AM | #17 | |
Rep 285
Do you remember feeling a large difference between your stock pads and the DS2500s? Im way past the limit of my tires and brakes in just the canyon runs so Im going to a more aggressive tire with the 2500s. Also doing the same as you with DS.UNOs front & 2500s in the rear for track days.
IG: lowkey_domm
08-10-2020, 10:52 AM | #18 |
Rep 305
I never ran the stock pads on the track and don't have canyons to run (S. FL) but I can say the 2500's definitly have higher initial bite than OEM pads when running around town. It's not neck snapping, but you can tell. My street driving style is pretty tame since I have track days to let it all out, so I won't be able to comment on modulation as it pertains to street driving.
lowkey_domm62.00 |
09-02-2020, 09:55 AM | #19 |
Rep 9
At the very least DS1.11 for the track. DSUNO and DS2.13 are also great. Also loved PFC 11 on this car.
09-17-2020, 06:49 PM | #20 |
Rep 112
I ran Hawk HPS, DS2500, then finally DS1.11 on the stock brakes. Hawk HPS was pretty terrifying. They shouldn't be used on track (nor street for that matter). DS2500 was pretty good on track. Doesn't have race-pad bite, but good modulation and only started fading towards then end of the session (at laguna seca driving 8/10). The problem with these pads is that they leave really bad deposits. I have some hard caked on deposits on rotors that will not come off. Probably need a resurface.
DS1.11 was fantastic, but too loud for the street. My setup is to swap between DS2500 for street and DS1.11 for track. DS2500 on rear for both. |
09-18-2020, 04:07 PM | #21 | |
Rep 285
After this year ill be looking to most likely upgrade too a 380mm 6 piston front and 4 piston rear with MRF fluid and same pads. Excited to feel the difference between BBK vs stock. That single large piston is still odd to me every time I see it.
IG: lowkey_domm
