11-20-2016, 02:29 PM | #1 |
Rep 103
RPM fluctuations, Fuel tank vent valve
So I have the same problem as other members have described regarding engine RPM fluctuations after filling the tank. Most opinions point to the fuel tank vent valve as the culprit.
My question is, where is it located for a DIY? Anyone done a DIY for this? Thanks |
11-20-2016, 02:43 PM | #2 |
997.1TT
1003
Rep 1,672
11-20-2016, 06:14 PM | #4 |
Rep 724
The fuel tank breather valve is a well documented problem. Irrelevant comments are just that. If you have direct experience please comment, does idle fluctuate if you fill up with the motor on?
Rat3d///M's DIY is one of the best in the DIY section. The details mentioned in removing the plenum are second to none. I experienced the symptoms mentioned, sometimes it only happened once after filling up other times it would stall multiple times. Some fill ups would not have an issue. Followed the DIY, issues I had and relevant comments are posted there. |
11-20-2016, 06:21 PM | #5 | |
Rep 103
11-20-2016, 06:23 PM | #6 |
Rep 103
11-21-2016, 07:31 AM | #8 |
Rep 1,148
Drives: 2008 BMW M3 Coupe
Garage List 2015 Jaguar XJ [0.00]
2015 Jaguar XF [0.00] 2014 VW GTI [0.00] 2008 BMW M3 Coupe [0.00] 2007 VW Passat 2.0T [0.00] |
You have to learn to trust the pump shut-off system, and not try to squeeze another 50 cents or so into the tank after it shuts off. I have never had this issue.
11-21-2016, 08:41 AM | #9 |
Rep 724
11-21-2016, 10:58 PM | #10 |
Rep 217
fuel tank breather valve Had same issue.completed under warranty. Havent had it since. Dealer had a hard time replicated it...I told to keep trying. After the 3rd fill up it.. happen. Crazy RPM..then stall. |
