      03-22-2018, 02:47 PM   #1
ec_E92
Enginerd
Drives: E92M3,E36M3,957GTS,E39M5S2
Tune2Air / Spotify no longer uses HU buttons?
Looking to see if anyone has insight here. At some point Tune2Air and Spotify stopped showing artist/track info on iDrive and steering wheel and head unit controls no longer change tracks. Volume buttons work.
Car is a 2008 (CCC), I'm on latest iOS iPhone 7 with latest Spotify app. I've tried resetting my Tune2Air and bluetooth connections.
Is there a setting I'm missing or is this no longer supported as of some software update?
2008 E92 AW 6MT /// 120k orig rod bearings
      03-22-2018, 02:55 PM   #2
qbnlykwhoa
Drives: 2011 E93 M3
Do you have any tracks in your iTunes library?
I noticed that steering wheel controls and track names would not work unless I had at least one song in my iTunes music library.
ec_E92117.50
      03-22-2018, 03:08 PM   #3
ec_E92
Enginerd
That's it, thank you! It probably stopped working about the same time I deleted iTunes from my phone because I was sick of it fighting with the apps I was using. Just restored iTunes and all good.
Guessing there is no work around still to prevent iTunes from taking priority? I know about the silent track method to at least keep it quiet while selecting preferred app.
      03-23-2018, 02:43 PM   #4
qbnlykwhoa
Drives: 2011 E93 M3
Cool, glad you got it working. Took me forever to figure that out! I haven't figured out a work around yet and I always check for firmware updates for the unit but none have been released.
      03-23-2018, 04:43 PM   #5
94jedi
Drives: 2009 e92 M3
How do you update the firmware?
I have an android phone and play pandora through the tune2air...I'm hoping one day I'll have a nice surprise and be able to control pandora (and least skip songs) through the steering wheel buttons.
      03-25-2018, 07:01 PM   #6
qbnlykwhoa
Drives: 2011 E93 M3
I have an iPhone and as long as I have a song in the library I can skip songs using spotify. That's pretty much how I listen to all my music.
Here is the site for the firmware, if they ever do have an update:
http://www.viseeo.com/ugC_Down_Detail.asp?hidShowID=22
You need to register to be able to see it. BTW my model is the WMA3000.
94jedi829.00
      11-19-2018, 03:06 PM   #7
slowm3sedan
slowm3sedan's Avatar
162
Drives: 2011 BMW E90 M3
Bumping an older thread to ask:
If I only have aux input will I be able to change songs? I just purchased tune2air 3000B and it seems to work the same like my other $30 Bluetooth Adapter.
I only purchased this so I can control the songs via steering well. If I can I'll most likely just return it and go back to my original one that worked fine but couldn't switch songs.
Thanks!
      11-19-2018, 10:05 PM   #8
ec_E92
Enginerd
Thanks!
Unfortunately you need the usb as well. The aux port is purely audio and carries no "logic" to change tracks or display info.
      11-20-2018, 08:53 AM   #9
slowm3sedan
162
Thanks!
Thanks for the response! Guess I should return it. No point to have a $90 streamer
Tags
spotify, tune2air, wma3000b bluetooth adapter
