02-22-2016, 08:29 AM | #1 |
Rep 53
WTB: Throttle Actuator Used/New
Anyone have a used or new throttle actuator laying around? Replaced the gears on mine and it turned out to be the board that was bad on the actuator. Car keeps going into limp mode and feels like a 318i. Text/call me at 42five7362three05 (I live in Kirkland)
Thanks, James |
02-22-2016, 11:36 PM | #3 |
Rep 2,526
This may help: http://www.m3post.com/forums/showthread.php?t=1227441
02-24-2016, 07:35 AM | #5 | |
Rep 53
02-24-2016, 07:36 AM | #6 | |
Rep 53
02-24-2016, 10:28 PM | #7 |
Rep 2,526
Jab555 , do you think replacing the gears as preventative maintenance would have prevented the board from dying? The gears are much cheaper than replacing the actuators.
02-24-2016, 10:34 PM | #8 | |
Rep 1,122
I was also able to source the replacement gears by odometergears for under $100 through a 3rd party auto parts site, so to me this was very cheap insurance compared to ~$800 an actuator. The replacement DIY is not particularly hard, but will take some patience. |
02-24-2016, 10:50 PM | #9 | |
Rep 2,526
Would you say your idle was sort of trembling before the replacement? |
02-24-2016, 10:59 PM | #10 | |
Rep 1,122
For the gears I posted a link over in the DIY thread, along with my ordeal regarding a different set of gears I picked up on ebay, but here's a direct link: https://www.carpartsdiscount.com/new...ml?3593=556050 It's also good to clean/lube all the throttle linkages as mine were quite gritty/squeaky and you may as well give the throttle bodies themselves a wipe. Lots of helpful info and advice if you are planning on doing this here: http://www.m3post.com/forums/showthread.php?t=735033 |
02-24-2016, 11:03 PM | #11 | |
Rep 2,526
02-25-2016, 09:50 PM | #12 | |
Rep 53
02-25-2016, 10:54 PM | #13 | |
Rep 2,526
03-03-2016, 12:31 PM | #14 |
coupe la goon
372
Rep 1,635
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
I have two used actuators from a replacement I did on my 08 last year. I'm in Portland.
03-04-2016, 09:47 PM | #18 |
Rep 2,526
07-17-2017, 10:09 PM | #19 |
Speed Demon
205
Rep 3,690
Bump. I'm in the market for another TVA, as well. Gear replacement didn't fix my problem, as I believe the board itself is shot, even though none of the mosfets look blown to me. I haven't tossed a multimeter on it yet, though, so...I could be wrong.
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i |
