  TireRack
      03-15-2021, 09:28 PM   #1
rebelliousfb
Max front tire width for AD08Rs on 19" rim?
I have the following setup currently...
F: 265/30/19 AD08R on 19x10 +25 VMR V710
R: 295/30/19 AD08R on 19x11 +25 VMR V710
I tried 305/30/19s in the back at first but they would rub on hard bumps at speed but there is absolutely no rubbing with the 295s.
For the fronts, I want to replace with the following...
275/30/19 AD08Rs on 19x10 +25 VMR V710
Everything I read on forums seems to indicate that I'll be fine with 275 fronts on this wheel size for my stock suspension/ride height but I also know AD08Rs tend to run wide. The reasons I want to go up are for a slightly wider track + thicker sidewall (8mm increase in total diameter) which will be nice as the current setup is very thin - not to mention the load rating goes from 89 to 92 which, while not overly important, is close to the stock 93.
What are your thoughts, will 275/30/19 AD08R fronts fit with no rubbing on 19x10 +25 VMR V710s?
Thanks!
      03-15-2021, 11:04 PM   #2
M43S7RO
Drives: Jerez Black E92 M3
I had 275/30 ad08r on those same size wheels in front, would rub the rear liner on full lock.
      03-16-2021, 07:59 AM   #3
rebelliousfb
That's disappointing. Thanks for sharing, much appreciated!
Search this Thread:
Advanced Search
