03-12-2021, 12:28 AM | #1 |
Rep 4,133
Cleaning MOST Fiber Optic Connector
Anyone tried cleaning the MOST Fiber Optic connector to the amp before? Any recommended steps to cleaning?
03-12-2021, 02:19 AM | #2 |
Rep 2,989
Electronic contact cleaner that's safe for plastics.
INSTAGRAM: GORDON.M3
DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI |
03-12-2021, 10:02 AM | #4 |
Lord Scrip
1802
Rep 3,006
Drives: 2011 M3 Coupe
Canned air and maybe a Q-tip. These fibers are not as finicky as real fiber optic cables used in data transmission which are measured in microns. Lol I once found a cut most in my 335 and used just the outer jacket of a red buttsplice to fix it. I cut both ends with a hot razor blade. These fibers are like little tykes fibers, all thick n shit.
03-12-2021, 03:10 PM | #5 |
Rep 2,989
Spray it on a q-tip and carefully clean it, you can use Isopropyl alcohol also.
The MOST connection usually doesn't need maintenance. Just give it a good duster spray so there isn't much dirt/dust. For the plastic/metal pins, use a spray contact cleaner to keep them from oxidizing.
03-12-2021, 06:18 PM | #6 |
Rep 4,133
Thanks all! I had super loud static coming thru the speakers suddenly when the car was parked with door open. I disconnected the amp MOST cable and it went away. Replugged the MOST and no more static, so I thought it might be a dirty MOST or something. Will try out your tips above.
