09-06-2020, 11:57 AM | #1 |
Rep 3,408
Harrop Plenum Removal Tricks
Any Harrop our other intercooler SC drivers have tips for removing the plenum/SC without making the worlds biggest coolant mess?
My thought is to run the pump and drain from the reservoir? Getting a recurring 2B0D combo MAP sensor fault. I replaced the primary O2s checked for exhaust leaks. The ICV only have about ~25k since it was changed under warranty at 15k miles. Probably replace the breather while I'm at it. Ideally I should test them both. When I run the diagnostics live stream, the values on the ICV and breather come on / off of showing value. After the faults occur generally there both not showing any values.
09-13-2020, 06:37 PM | #2 | |
Rep 3,456
Drives: Harrop E90 M3
DRLane3985.50 |
09-13-2020, 07:36 PM | #3 | ||
Rep 3,408
MilehighM3914.00 |
