10-17-2017, 07:48 PM | #1 |
Rep 54
(pics inside) damaged skid plate / under belly plate
Item is out of stock at dealership, and is a 4 piece plastic cover that runs ~$600 I was told. Are there aftermarket options? I don't want to leave it exposed (especially since one of the hoses is bent, see image). There are some posts of people fabricating their own out of aluminum, and I'm not sure if the Ebay ones can be trusted to... shatter reliably to protect the bumper. Is this a good replacement? http://www.ebay.com/itm/ProTEKt-BMW-...-/301566593702
Also, a few hours after this happened, the TPMS went off. Does any one know if the dangling cable is related to it? Everything is working normally and there are no codes stored. |
10-17-2017, 08:22 PM | #2 |
Rep 12,736
you don't need those skid plates, you need these three pieces.
https://www.ecstuning.com/b-genuine-...51757899820kt/ and no, you don't want to leave it exposed, your car will run warmer because those pieces help with airflow through the coolers. i don't know what that plug is for just by looking at it... might be for tpms antennae. where in california are you?
ghostofsenna129.50 |
10-17-2017, 09:21 PM | #3 | |
Rep 54
10-17-2017, 09:21 PM | #4 | ||
Rep 12,736
10-18-2017, 12:47 AM | #6 |
Rep 5,034
It looks like either that wiring connection got pulled out, or you have totally lost a tpms module. There are 4 total on these cars, 1 at each corner of the vehicle. On the fronts they are attached to the front section of the fender liner via 2 expanding plastic rivets. You can easily find a replacement on ebay if needed. Look on realoem to find the part number, and you will see that these modules are used across different bmw models as well as mini.
10-18-2017, 05:32 AM | #7 |
Rep 331
That connector is to the TPMS antenna located in fender liner. Plug it back and TPMS should be good. Get the belly pan kit from ECS and anyone can install it.
Past: E82 135i Crimson Red | MPE | MHD Stage1+ | Dinan Camber Plate | LCI Blackline | Bavsound stage 1 | KW Coilover V2 |
Past: E93 M3 Vert Alpine White | Remus Sport Exhaust | Past: F82 Yas Marina Blue Civic M4| MPE V2 | DP | BM3 | Apex FL-5 | MP Part(s) | Current: F87 M2 Competition Long Beach Blue | Completely Stock | |
10-18-2017, 06:45 AM | #8 |
Rep 2,912
Drives: 2011 E93 M3
Here is the only aftermarket alternative that I know of. I can also help with used parts to help save money.
http://www.m3post.com/forums/showthread.php?t=1364151 |
BOOF-M34451.50 |
10-18-2017, 09:48 AM | #9 | |
Rep 386
deansbimmer3769.00 |
10-18-2017, 06:32 PM | #11 | |||||
Rep 54
Gonna look into this, do you know price? Quote:
Do you know how much this was? |
