10-20-2022, 03:41 AM | #1 |
Rep 270
FS: Brembo GT full BBK, 380mm rotors x 4, brembo high temp pads and braided lines
FS: Brembo GT full BBK - Front 6 pots and Rear 4 pots Calipers, 380mm rotors x 4, brembo high temp pads and braided lines
Brembo GT Full Kit - Front and Rear Calipers, 380mm Rotors x 4, Brembo pads and braided brake lines Used for 20,000km, like most used BBK's the paint is nicked up in places around the outer edges but not on the faces where it's visible once installed. The front rotors and hats are recently new with no measurable wear. The rear rotors have worn less than .5mm from new. Includes high temp street pads and brake lines. Off a e92 335i fully built n54 single turbo pushing 500rwhp, can be modified to suit e9x m3 or f8x m3/m4 with new caliper braket See f80 m3 review below: https://f80.bimmerpost.com/forums/sh....php?t=1289067 Brand new rrp front kit is $7,995 and rear kit is $6,595, with a total replacement cost of $14,590 from Southern BM, grab yourself a bargain: https://southernbm.com.au/products/b...rd?category=54 https://southernbm.com.au/products/b...ge?category=54 Selling $6,500 pickup from Northmead NSW, can post at buyer's expenses around $200 to $250 depending on location
Sapphire Black M4 | iPE - Valvetronic exhaust | VRSF 3″ catless dp | Bootmod 3 Stage 2 | OEM LED alcantara steering wheel | OEM M4 GTS CF hood | Vorsteiner GT wing | M Performance CF splitter | Vorsteiner CF front lip | M Performance CF side skirt extension | 3D CF diffuser | OEM CF mirror cap | H&R lower spring | Rays Engineering TE37 Ultra Bronze 20x10F 20x11R
11-06-2022, 01:26 AM | #2 |
Rep 270
Price dropped to $4,500
11-08-2022, 03:15 AM | #3 |
Rep 2
Evening,
A few quick questions; 1/ Is this BBK from a donor vehicle or the actual kits for the front and rears in the links provided above? 2/ Do you have the QR code for the brakes or info located in the link; https://www.bremboparts.com/asiapaci...roducts-247245 Cheers! Justin |
11-10-2022, 08:02 PM | #4 | |
Rep 270
Please find attached are part number stamped on the calipers, Brembo GT 6 piston calipers part number 20.9733.01 and 20.9733.02 |
11-11-2022, 09:23 PM | #5 |
Rep 270
SOLD
