04-10-2010, 03:11 PM | #1 |
#thatsanicemovebro
204
Rep 3,920
Drives: E92 M3 LSB/Black 6MT
Feasible to switch out stockers/BBK w.r.t the seasons?
Basically wondering if it makes sense to buy a BBK and only use it in summer months. I live in a city that has horrid winters, and I think that a BBK is completely unnecessary in the winter months. I was thinking of getting a BBK (maybe one that doesn't even fit under the stock 18s which would be winter rims) and switching it in when I would change my rims to the summer setup, and switching it out when I would change back to winter rims.
How long would this process take? Does this make any sense? I would not like to put unnecessary wear on the BBKs and I think overall this would allow everything to last longer. Opinions welcome. Best G |
04-10-2010, 04:52 PM | #3 |
#thatsanicemovebro
204
Rep 3,920
04-10-2010, 04:55 PM | #4 | |
C
51
Rep 724
04-10-2010, 05:13 PM | #5 |
Rep 9,034
It's feasable, but it's around $400 for install/flush around where I live. Unless you go to LTBMW.
04-10-2010, 05:36 PM | #6 |
Moderator
683
Rep 4,737
1. You can get a BBK that fit under 18" wheels. Many here have reported excellent performance with a smaller diameter set up. AP, Brembo, StopTech all make 18" wheel friendly set ups.
2. You can get a 19" winter set up. Remember, when you switch out BBK, you are switching calipers, brackets, brake lines, and discs. You will also need to bleed your brakes afterwards. Quite a tedious process IMO. |
04-10-2010, 06:04 PM | #8 | |
#thatsanicemovebro
204
Rep 3,920
2- I ordered the car with 18s and do not want to sell them. Also, 19" winters are harder to find and 19" wheels hurt where I live lol... Overall, how long would this whole process take (switching them out)? I see what you're saying though... |
04-10-2010, 06:44 PM | #9 |
e36s54, e70x5d
155
Rep 1,723
Switching out the brakes is actually easy .... 2 giant bolts for the bracket .... and three small bolts for the rotor.
What sucks and takes time & 2 ppl ... is bleeding the brakes properly everytime you change from OE to BBK and back. Otherwise, it would be easy and I would do it if I lived where u do. |
04-10-2010, 06:53 PM | #10 | |
#thatsanicemovebro
204
Rep 3,920
But let me ask you, if a competent mechanic would do this - how long would this take? |
04-10-2010, 07:38 PM | #11 |
Moderator
683
Rep 4,737
Most shops are gonna quote you about 3-4 hours.
Wear and tear during winter on your rotors will be much less expensive vs. labor of putting BBK on AND off annually (6-8 hrs). |
04-10-2010, 08:20 PM | #12 |
#thatsanicemovebro
204
Rep 3,920
04-10-2010, 08:48 PM | #13 |
Rep 3,848
I live in Toronto, had a BBK on my last 3 cars, don't worry about the winters. Don't waste your time or money swapping it out.
Replacement rotors are $$$, but they last much much longer then your OEM ones.
04-10-2010, 08:52 PM | #14 |
#thatsanicemovebro
204
Rep 3,920
Can you define $$$ because I want to get a sense of what to expect (PM me if you want). Thanks for the advice.
04-10-2010, 09:00 PM | #15 |
Rep 3,848
Brembo 380mm rotors and necessary hardware, each corner will probably run you $800 to $1000. Double check this figure though, don't want to stray you wrong.
BUT, they last a very very long time. I would say 3 to 4 times longer then OEM at least, with track use.
04-10-2010, 09:06 PM | #16 |
#thatsanicemovebro
204
Rep 3,920
So it ends up being the same in the long run ($$). And you get much better quality...Thx
04-11-2010, 11:35 AM | #17 |
Rep 203
04-11-2010, 12:17 PM | #18 |
#thatsanicemovebro
204
Rep 3,920
I know...and it makes absolutely no sense to me...Compared to the stock set-up, I have actually read that the braking in regular situation is not improved or even a little worse (especially with some more track-tuned pads that come with the BBKs)
04-12-2010, 12:44 AM | #19 |
chris
290
Rep 12,144
dont get the bbk yet. Try aggressive pads and ss brake lines. You'll be surprised how much punishment the stockers can handle. Unless u're trying to do this more for cosmetics.
04-12-2010, 01:31 AM | #20 |
Rep 3,848
Not sure if you are interested, but I am selling these.
http://www.m3post.com/forums/showthread.php?t=347598
04-12-2010, 01:48 AM | #21 | ||
#thatsanicemovebro
204
Rep 3,920
I am planning ahead - the upgrade will be in 2-3 years or when the stock brakes are 100% finished. Quote:
04-12-2010, 01:57 AM | #22 |
Rep 2,266
I had a 365mm kit for about 65000km(3 winters) in Toronto's weather.. I only had to change my rotors cause my dealer gave me bad info on my pads remaining.... definitely not worth swapping in and out. But I did notice that my rotors had unusual rust spotting around the drilled holes... other then that, it worked perfectly fine.
Cheers
Ben |
