03-31-2010, 11:52 PM | #1 |
Rep 5,018
Have any of you reset the brake fluid service after a DIY fluid change?
Curious if that can also be reset with the procedure posted somewhere here to reset oil changes and such. I'm also seeing that an 'emissions inspection' is going to pop up pretty soon, and would need to clear that one too. In fact, I'd like to disable that one (many cities don't require it, so it should be programmable). Prefer not to dick with those menus without guidance since somebody reported accidentally resetting an oil change before it was due (oops!). Thanks gang.
04-01-2010, 12:18 AM | #2 |
Moderator
683
Rep 4,737
http://www.e90post.com/forums/showth...reset+computer
This is what I used. You should be able to use this to reset all service items. |
04-01-2010, 11:06 AM | #3 | |
Rep 5,018
Now, since my service indicator is not lit yet, should I wait until it turns red, or can I reset now and it'd show April 2012 for the next brake fluid, or would it turn 2 years after the current date, which is Jun 2010? Or maybe we can't even reset a green indicator, no? Finally, since I'm not resetting an oil change, which is the first item to pop up, at what point should I toggle the switch for other maintenance items? After the first long hold of the odo button or the second??? Hope the former. Thanks again man. |
