09-09-2019, 12:58 PM | #1 |
Rep 130
KW Clubsport 2 way setup
Hey guys,
Just installed KW Clubsport 2 way on my e92 m3 with style 513 18" wheels. I'm currently running 255 and 275 tires. I did the install myself everything went smooth but I am trying to find the right bump/rebound and ride height. Anyone have good setup numbers? The manual recommends 6 front 9 rear "open" for rebound and 1 full turn for bump. Im assuming this means closing these settings by turning clockwise till stop and then opening counterclockwise with the above recommended clicks. Would like some recommendations on ride height as well. I live in NY so roads are not the best but this is a weekend car that goes to track few times a year. Thanks! |
09-11-2019, 06:20 PM | #3 |
Admiral
930
Rep 3,886
There's really no "one size fits all" setting for suspensions.
You should get the car corner balanced after selecting a ride height which suits your personal preferences. If you are primarily driving this car on the street, definitely go with alignment settings near stock, possibly slightly more aggressive than stock. Generally around -2.5F/-1.8R is a common setup for dual purpose driving. There's no "factory" KW CS camber settings, it is only the factory vehicle setting that really matters. In regards to dampening settings, I recommend starting in the middle, and adjusting to your own preferences. Best of luck!
09-12-2019, 08:51 AM | #4 | |
Rep 130
09-12-2019, 11:04 AM | #5 | ||
Admiral
930
Rep 3,886
09-12-2019, 11:27 AM | #6 |
Rep 1,591
For adjusting the dampening, you're correct: fully close them then open them the number of clicks KW recommends, it's a good baseline to start with.
With regards to alignment, it depends on how aggressive you want to get.. Around -3*F/-2.2*R would be a good starting point, go less if you want to drive the car on the road more regularly. The kits camber for the front will be based on your existing camber, then you can use the camber plates to increase it from there. Rake wise you'll want to be between 1/4"-1/8" positive rake (front lower then the rear). Bimmerworld recommends measuring this difference from the F vs. R jack points. Last edited by tsk94; 09-13-2019 at 11:11 AM.. |
09-13-2019, 11:11 AM | #8 |
Rep 1,591
Yes, you're correct. Typo of my end
Expanding on ride heights and rake. I've found they made a significant difference in the handling balance of the car. At the start of the season I had a much more aggressive rake set on the car (rear higher compared to where it is now, front has remained the same). It was a new race car build so our baselines were very much baseline starting points.. The car was was very pointy on the front end and the rear was very loose from corner entry to mid corner. In addition to sway bar tweaks, lowering the rear to where it is now - currently running 1/8" rake - made a massive difference in rear end stability. This is often an overlooked and seemingly rarely talked about method for tuning handling balance. The same can could be done if the car was understeering, either lower the front or raise the rear to promote more rotation (less understeer). Last edited by tsk94; 09-13-2019 at 11:18 AM.. |
09-18-2019, 04:07 AM | #9 | |
Driver
2692
Rep 2,714
