| 09-18-2025, 05:54 AM | #1 |
![]() 13
Rep 46
NCS Expert: Error in CABD! EDC Coding help please
Hi guys,
Hope you can help. I am trying to code out EDC in my E93. I have completed nearly all the necessary steps but feel like i am failing at the final hurdle. These are the steps I have completed successfully: 1. Unplug blue cable from EDC module in trunk 2. Remove 223 from VO (in both CAS and NFRM) 3. Set EDCK_ALIVE_ZAEHLER to nicht_aktiv and EDCK_ID_MONITOR to nicht_aktiv in KOMBI However, when i create the TRC file for CIC, set EDC_CIC to nicht_aktiv, rename to MAN and try to code back to the car using NCS, I get the following error: Anyone have any ideas? Thanks Last edited by E93M3MW; 09-18-2025 at 06:20 AM.. |
| 09-23-2025, 03:31 AM | #4 | |
![]() 13
Rep 46
That is 100% correct. I successfully changed the VO but assumed i also needed to recode the KOMBI and CIC. VO changed, fault cleared using INPA and no more EDC light. Thanks! |
| Bookmarks |
| Thread Tools | |
