      09-01-2025, 01:52 PM   #1
Pincopallino74
Drives: e93 M3 LCI LE500/ X5 /R53
Tv retrofit help
Hi all,
I have an issue I retrofitted the TV and new CIC with DAB.
on my E93 LCI
VO added (601)
I have coded the CIC ( used the dvb-t and all the rest of the coding for the search and epg and so on) cables are laid and the vert is 21 ( fbas connected to pin 2-8-7 on the tv module and 28-18-27 on the cic) plus and minus connected and fuse installed onto f18
The unit is present in ista is reachable, however when pressing search channels it doesn’t do anything.
I checked on ista and when I go and do a test for the aerial tells me that test is not available before I need to activate the TV function.
I cannot seems to make it work.
Am I miss something here?
Thank you in advance to you all
