01-19-2019, 10:28 PM | #1 |
Rep 28
Hey folks, am looking for some help pls.
I've searched here and elsewhere for an answer to this without success but expect the question has been asked before... See pics. These "vents" at the windshield corners excel at catching fine grains of crap that sift through the plastic grills. I now have a heap of dirt building up from their base that I suspect would be mighty fine for a garden bed, but less desirable in an automotive situation. Beyond the top opening, their width is too thin to accommodate and cleaning hand. Ive also not been able to locate a point of exit under the car. So: - Is there in fact an exit, and if so where? - Any tips out there for cleaning these suckers? Thanks in advance team. |
01-19-2019, 11:39 PM | #5 |
Rep 28
01-20-2019, 01:23 AM | #6 |
mTekMods
2142
Rep 2,902
Pull the cap out duck tape it and put a small hole in it then fit a air blower into it preferably fed through a 1/2” air line. Vacuum it out first.
01-20-2019, 04:13 PM | #7 |
Rep 553
That's a drain that is meant to drain off water that accumulates there. There should be an exit almost directly below the vent. This is why the top of your foot gets wet while after you dry the car and leave it there for a second. The screen does pop out if you need to clean further down there. I've used a shop vac with the narrow attachment. Hope this helps.
01-21-2019, 09:02 AM | #10 |
Rep 1,293
If you happen to have an old garden hose, cut the male end off the hose and shove the hose down the hole with the water running. Like you mentioned, it will blow a bunch of rich compost out the drain in the bottom of the car. Works like a charm.
DrFerry6728.50 |
01-24-2019, 07:31 PM | #11 |
Rep 12,726
if you don't have air, get a stick and wrap some duct tape backwards around the end of it. just stick up a little at a time and wrap it again and repeat.
02-02-2019, 04:27 PM | #12 |
Rep 84
02-02-2019, 04:34 PM | #13 | ||
Rep 28
By means of update - I'm yet to locate the exit point of these things dammit. Time to elevate the car.. |
02-08-2019, 07:26 PM | #15 | |
Rep 4,107
2021 X3 M40i
02-20-2019, 05:24 PM | #16 |
Rep 6,218
so many ways recommended.
Just grab some tongs from your kitchen. then go to gas station and blow it all out with the air hose.
