06-07-2010, 01:42 PM | #1 |
Rep 254
Shifting from 4th to 5th in MT
So, being fairly new to a manual, I'm having a hard time shifting from 4th to 5th without the rear bucking. Trying to conserve fuel, I'm shifting between 2600 and 2900. I'm fine for the lower gears as I'm holding the clutch pedal in for just a moment after shifting before pulling up on the clutch pedal, but for the shift from 4th to 5th, I feel like I have to keep the clutch pedal in for a couple of moments longer or else I get the buck and even then it's hit or miss. The RPM's drop so fast when the clutch pedal is down that I can't shift fast enough. Am I supposed to be on the gas a little before letting the clutch out or should I not push the clutch pedal all the way down? How do you guys/gals shift? Am I shifting way too early for 5th?
jms_w '08 E93 M3 SG | BLK | 6MT |
06-07-2010, 01:46 PM | #2 |
Rep 273
Drives: 2009 IB M3 Coupe
IMHO you're shifting at too low an RPM. Try it at 4000+ RPMs. I think you'll find it much smoother.
2009 M3 coupe,interlagos blue,6mt,loaded,19" hre comp 97s,powerchip,h&r springs,hamann front splitter,eisenmann race exhaust
Delivered 7/10/09 |
06-07-2010, 01:47 PM | #3 |
Rep 1,211
That is result of the low-mass inertia of the flywheel. The car has a very light flywheel in order to allow fastest access to redline. Since the purpose of the flywheel is to store energy so that the car can easily get off the line, lighter flywheel trades the smoothness and ease of getting off the line without much throttle input for exceptional response and ability to rev.
Personally, that is the beauty and fun of driving a manual transmission. The quirkiness. It is an art form that requires mastering differently for different cars. Give it time and you will see it will become second nature to you as you will develop a way yourself to shift smoothly. The daily driving gets a little tricky with a very light flywheel. A way to handle this (takes some practice) is to quickly blip the gas a bit before releasing the clutch. It is a delicate balance that takes some practice.
""A great sounding, responsive, high-revving, naturally aspirated engine is part of the DNA of a thoroughbred sports car. No two ways about it."
- Lamborghini on turbocharging |
06-07-2010, 02:02 PM | #4 | |
Rep 4,144
Shift 3000+ rpm.
Push it all the way down. Shift at a higher rpm. It's a little trickier but you'll get the hang of it the more you do it. Up or downshifting, try to make it smooth by matching revs. Again, it takes practice. But when you do it perfect it's as good as sex. Cheers.
2017 F80 YMB.
06-07-2010, 02:21 PM | #7 |
Rep 254
Thank You all for your advice. It sounds weird to rev match on upshifts as I've only heard it done on downshifts but I'll give that a shot. But question about rev matching, I know it's down while clutch pedal is down but do I blip the throttle while in 4th gear, neutral, or 5th gear before I let the clutch out? I can never figure this out.
06-07-2010, 02:24 PM | #8 |
Rep 3,882
Try watching these, he's pretty good at teaching, I thought.
If you're bucking going 4th-->5th, then chances are you're most likely shifting too early. Like most people have said in this thread, try shifting at higher RPM's, like 3,500+. Rather than getting used to rev matching during upshifts, you should just get used to doing it correctly. Bad habits are easy to make and hard to break, after all. Last edited by LateBraking; 06-07-2010 at 02:32 PM.. |
06-07-2010, 02:35 PM | #9 | |||
Dog Listener
703
Rep 7,850
Here's "my" method--the thing is to try several things and find what works best for you and your style. Just keep your foot a bit on the throttle and don't lift all the way off. Keep some pressure on it, and if done correctly the revs will be at just the right level (just above where they'll end up when you let off into the next gear). It's not so much a "blip" (but okay to think of it as such as if it helps) as much as "don't let the rev fall to fast" exercise. You're just trying to keep the revs from falling too fast too far (e.g., let them drop from 3K to 2K, not to 1.5K). Even shifting at higher RPMs without doing this in some cars will result in a lack of a smooth shift (the Z4M being one of those, especially 1st to 2nd). Think of the having an egg between your foot and the throttle--you don't want to let the egg roll off onto the floor. (Have to give credit to my wife on that one--she's the master of all things shifting on the Z4M, which makes shifting the M3 seem like a breeze in comparison....) The "blip" is more of a downshift thing, there you need to actually get the revs up past where they were (e.g. 3K to 4K). Quote:
You've got a heck of a good point there! It's taken me a long time to stop fully "lifting" off the throttle on upshifts. Bad habits die hard. Last edited by Finnegan; 06-07-2010 at 04:14 PM.. |
06-07-2010, 03:52 PM | #10 | |
Rep 1,211
It is only to bounce the revs back up a bit so that the flywheel can spin a little faster in order to make it smoother.
Anyway, people have been recommending shifting at higher rpms, which is probably a better solution. Quote:
06-07-2010, 04:13 PM | #11 |
Dog Listener
703
Rep 7,850
06-07-2010, 04:59 PM | #12 |
Rep 1,211
Yes, that is a very effective trick. Do not lift foot toe entirely off the gas pedal while shifting. Stop when there is 10 - 15% travel left using light toe weight that will complete the throttle from being fully closed, which means the flywheel will lose speed slower.
06-07-2010, 07:28 PM | #13 |
Rep 5,012
Finnegan made a good point. You should be able to shift smoothly regardless of rpm. But yes, 4-5 is probably the trickiest shift on the M3; I still can't get it smoothly half the times.
And yes, I need to practice the 'rev hanging' technique for smoother (and leisure) upshifts too. I have no problem when shifting quick enough for the engine to be at the rpm of the next shift, but with the S65 dropping rpm like a rock, you need to shift quickly indeed. And sometimes you just want to take your time . And that's where that 'rev hang' technique comes handy. I'll try it too. It's funny how I've always hated rev hang on most of my manual cars, but for the first time, wish the M3 had a little bit of that. The good news is we can provide it with practice. Good suggestion gang. Now we have a reason to drive our cars more; I always like to be smoother. Later. |
06-07-2010, 08:29 PM | #14 |
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
Just keep driving the car, you'll get a real nice feel for it. There is a pretty good learning curve with this car regarding smooth shifts.
06-07-2010, 08:41 PM | #15 |
Rep 311
Skip 5th and go straight to six. Smooth as a jelly fish.
SIGPIC][/SIGPIC] 2008 M3 SSII 6MT, EU Bumper, Matte Black Kidneys, AA Pulley, 12/10 RE Spacers, MS Filter
06-07-2010, 08:51 PM | #16 | |
Rep 150
Its just a matter of getting used to the car. I've shifted anywhere from 2500 to 7500 RPM. It can all be done smoothly with a little practice. Learning to modulate the clutch pedal and throttle effectively just takes practice. One of the reasons I've never been interested in either the SMG in my E46 or the DCT in my E92. I like to be able to finesse the clutch and throttle. As an aside, the throttle by wire also takes a little getting used to over time. Once you're there, you're going to really enjoy the car. |
06-08-2010, 11:31 AM | #17 |
Rep 331
Agree with everything said here, but you're really not saving much fuel by shifting at 2900 RPM. The problem is that you're basically letting the car fall to idle before engaging the next gear.
I usually shift around 4K for normal driving. That seems to be the 'magic' point for smoothing everything out without having to balance revs on an upshift. MPG is not noticeably different from when I used to shift at lower points. |
06-08-2010, 10:25 PM | #19 |
Rep 69
it comes with practice. also shifing 3000+ rpm is a little smoother. the drop in rpm between 4th and 5th that low in the rev range isn't very big so the revs are likely dropping lower then having to catch back up with the gear ratio. (for lack of a better explaination). the difference in rpm between the gears gets larger and larger as you move up the rev range.
also the 4th to 5th throw is longer. i often find that i hit the passengers knee when i shift to 5th if they lean their leg againt the centre console |
06-12-2010, 02:47 AM | #20 |
Rep 911
i notice its best to shift the car at 3000rpm as well. its so odd to be shifting a v8 that late, but then again this car revs to 8400.
do other people shorten their clutch travel distance? meaning instead of pushing the clutch all the way down, full travel, just press it down about 30% and shift? i found doing that makes the between shifts smoother (only concern is if it will damage the clutch). i found my 1st gear to jerk the car back and forth when the transmission is just warming up or maybe its the drive-by-wire system? anyone else experience this? |
06-12-2010, 07:56 AM | #21 |
Rep 562
Drives: 2011 M3 Sedan SSII/SN/DCT
I havent driven a M3 MT, but with just about any MT for smooth shifting, if your RPM's are above the sync RPM for the next gear, or below, it will buck. When you shift from 4th to 5th gear, take note where the RPM settles for 5th. If your RPM is consistantly higher, let off the throttle completely before pushing in the clutch to shift gears. This will create decelerating momentum on the flywheel. If the RPM is below the sync RPM when you shift, simply shift a little quicker.
