02-16-2019, 04:31 AM | #1 |
Rep 17
Do I have a problem with my oil indicator?
Hey guys...New owner here. Have the car now since November.
It's frustrating that these cars don't have an oil dipstick because I am not sure if I should be changing my oil or not. Ever since I got the car my oil level indicator has been at the very top of the line. It hasn't moved at all. Is this normal or is it broken? I've only driven it about about 2500 KM. The thing is the OIL engine service indicator in the screen says it's overdue for an oil change by about 500km or so. I don't know what to believe. The previous owner also said it should be due for an oil change soon. I lost my PPI paper but I think I remember it saying the oil levels were good.... So do I just go for an oil change even though my oil indicator level is at max (at the very top of the line) |
02-16-2019, 05:40 AM | #2 |
Rep 12,724
its normal.
the oil level indicator is like a digital dipstick. the bottom line is the minimum operating range, and the top is the maximum operating range. anywhere in there, and you're good. it has nothing to do with oil life, even if your car consumes a little bit of oil between changes. if your car is asking for an oil change, it as probably reached the 24kilo bmw oil service interval. get it changed, and then change your oil about every 12km from here on out. monitor the level from time to time.
02-16-2019, 09:47 AM | #3 |
Rep 4,160
Oil change intervals have nothing to do with oil levels. Your oil can be full, but if it's due for change you need to change. Vice versa also holds true - just because you have low oil levels doesn't mean you need to change the oil, you can just top up.
02-20-2019, 03:54 PM | #5 |
1916
Rep 1,878
Regarding the oil level indication, were you expecting some of the oil to be burned over the course of the oil change interval? If so, welcome to the "Engines That Don't Burn Much Oil" club.
