11-12-2018, 05:32 AM | #1 |
Rep 91
E92 M3 Battery Discharge, clock reset and ABS issues
Hi there,
Hoping somebody here is able to help me. I bought an E92 M3 on Friday. Its a 2007. I took the car for a drive on Saturday but when I started the car got the following warning "Increased Battery Discharge" and the clock needed reset. I reset the clock and went for a drive a few miles down the road the ABS, DSC, DBC and FTM failure warnings appear on the iDrive. I am hoping they are related to the discharge issue. Got home and attached a trickle charger to the car but it woldn't go over 11 volts and the battery is the original battery that came with the car and the previous owner has had the car parked up for 6 months. Got a replacement yesterday and fitted it. It was an AGM battery and the same CCA as the battery I replaced. Took the car a drive no errors on the dash. I got into the car this morning the increased battery discharge issue is back and the ABS lights are back on and the clock needs reset. I checked the voltage of the battery and all is healthy. Drove the 50 mile commute to work and shut the car off. Came back 10 mins later and started the car the increased battery discharge warning appears again and the clock needed reset along with the ABS lights. The new battery hasn't been registered to the car yet as I am waiting the cable to arrive so I can register it and read any logged codes. If anybody has any pointers it would be great |
11-12-2018, 07:44 AM | #2 |
General
63421
Rep 24,689
EDC ?
chrisymarr18.50 |
11-12-2018, 08:05 AM | #3 |
Rep 91
Yeah the car has EDC
///M Power-Belgium63421.00 |
11-12-2018, 08:28 AM | #4 | |
Rep 91
The battery I took out has a cold crank amperage of 800 and the battery I replaced it with also has a value of 800. I would assume though due to the last battery being 11 years old it was degraded so the alternator will still be charging as if the old battery is in place? |
11-12-2018, 09:46 AM | #5 | |
Rep 91
I have also read somewhere not sure if there is any truth in this if the battery completly dies a lot of fault codes becomed stored and have to be cleared before regular charging will come back |
11-12-2018, 09:48 AM | #6 |
General
63421
Rep 24,689
A faulty EDC module can drain our/your battery pretty quickly , saw this more than once..
Check your start/stop button , if the button stays longer illuminated than normal . Your EDC module is faulty .
chrisymarr18.50 DrFerry6728.50 |
11-12-2018, 09:50 AM | #7 | |
Rep 91
I locked the car last night and came out 8 hours later and it was off, but I am unsure what the expected length would be for the button to be illuminated. Would I be safe to just unplug the EDC module? |
11-12-2018, 09:58 AM | #8 | |
General
63421
Rep 24,689
Yes . You can unplug your EDC module.
DrFerry6728.50 |
11-12-2018, 10:04 AM | #9 |
Rep 91
11-12-2018, 11:40 AM | #10 |
Rep 91
So an update
Drove home from work (50 mile journey) Got out locked the car and waited to see if the start stop button stayed illuminated. It powered off after 5 mintues of the car being locked. Once the starter button turned off I waited another 5 minutes then started the car. Increased battery discharge and the clock had to be reset again. Surely there wouldn't be such a drain to want it to reset within 10 mins of shutdown from a 50 mile drive? |
11-12-2018, 01:10 PM | #11 | |
General
63421
Rep 24,689
Keep us posted about your situation..
chrisymarr18.50 |
11-12-2018, 01:21 PM | #12 | ||
Rep 91
I am assuming its something to do with the battery not being registered so once my cable arrives I will clear the codes with INPA and register the battery and hopefully the solves it. As long as its not the IBS is faulty. I hope its not the alternator but if it were the alternator would it not be discharging whilst the car is running? |
11-12-2018, 01:54 PM | #13 |
Rep 91
11-12-2018, 02:26 PM | #14 |
General
63421
Rep 24,689
Normally not .
chrisymarr18.50 |
11-12-2018, 03:54 PM | #15 |
Rep 60
OP
I have a 2008 and mine did the same thing. I replaced the battery and still had issues. As it turns out, it was the alternator....I replaced that and had no issues since then |
11-12-2018, 04:02 PM | #16 | |
Rep 91
Just seen they are quite cheap on eBay so may be a good thing to try. Did you also have the DSC and ABS issues? |
11-12-2018, 06:00 PM | #17 |
Rep 1,385
That’s what was killing my car. It was waking the car up when it was off which was killing the battery.
///M Power-Belgium63421.00 chrisymarr18.50 |
11-12-2018, 07:09 PM | #18 |
Rep 254
OP, same as above. the alternator was working just enough to get started then went ape shit mid drive. took Indy shop about a day to diagnose.
E90 ///M3 Silverstone II '11 (current)
E90 ///M3 Silverstone II '08 E46 ///M3 Alpine White III E36 ///M3 Arctic Silver E46 ///M3 Carbon Schwartz |
11-13-2018, 12:41 AM | #19 | |
Rep 91
Do you think the alternator could still be faulty and not providing enough charge? |
11-13-2018, 09:13 AM | #20 |
Rep 91
Thanks I will get a voltmeter to the car this evening. Is the onboard voltage check reliable?
11-13-2018, 11:32 AM | #21 |
Rep 7,113
Yeah a quick start and check voltage will tell you whether alternator is out. On board meter should do. For instance Carly also present alternator output current, as possible next step.
Good luck |
11-13-2018, 12:47 PM | #22 |
Rep 91
Thanks all for the pointers
Used the onboard meter Battery with ignition on and engine off 11.9 volts Engine on, heated seats on, blower full speed and headlights on: 14.4 volts [IMG] [/IMG] |
