01-06-2018, 03:57 PM | #1 |
Rep 2,138
Drives: 2011 E92 M3
E92 with ZCP Spacer and stud questions
After doing some reading, I ordered Macht Schnell 15mm spacers for the front and 12mm spacers for the rear. I also ordered 95mm F and 75mm studs R. Unfortunately they sent studs for the newer F type BMWs so they will not fit (why would BMW change to 14mm studs...). Positive note, they are sending me new studs
My question is: has anybody used Macht Schnell 15mm spacers with Macht Schnell 75mm studs? If so, do you get the proper 6.5 turns of thre4ad engagement? Reason I ask is I have serious OCD and I am worried that the different stud lengths will drive me nuts. If I cannot use 75mm studs on all 4 corners, I will likely return the 15mm spacers and 95mm studs and just go with 12mm spacers with 75mm studs on all 4 corners. OCD is a wonderful thing... Cheers,
01-06-2018, 04:43 PM | #3 | |
Rep 2,138
Drives: 2011 E92 M3
I think I will change things up and use 12mm on all 4 corners with 75mm studs.
01-08-2018, 12:42 PM | #4 | |
Rep 1,408
01-08-2018, 12:43 PM | #5 | |
Rep 1,408
01-08-2018, 09:17 PM | #6 |
Rep 2,138
Drives: 2011 E92 M3
For sure! Thanks.
