09-01-2021, 02:59 PM | #1 |
Rep 215
boesner 8.8 bolt
hey im putting everything back from my rod bearing job. i remember taking these 2 bolts out from the front passenger side of the car but cant remember or see exactly where they go.
they say bosner 8.8 and are about 4 and half inches long [IMG][/IMG][IMG][/IMG] ive been looking all day thanks |
09-01-2021, 04:18 PM | #2 |
Rep 3,987
Don't look familiar, shouldn't be from the car unless someone put in some non OEM bolts.
The only bolt similar would be from the subframe like this, earlier cars come with a hex head vs etorq.
09-01-2021, 04:39 PM | #3 |
Rep 215
appreciate the post . i have no idea where i took it out of and i dont want to uninstall everything. than it bothers me to find out its something critical if i was to start the engine.
09-01-2021, 05:07 PM | #4 |
Rep 215
yeah my subframe bolts are all hex heads but these 2 came from the front of the car passenger side area. i remember a tight space side of the pully area . im gona buy a camera to record tight spaces to see anything
09-01-2021, 07:37 PM | #5 | ||
Rep 215
isnt the alternator on the driver side? i got this from the passenger side. i order a endoscope to help me track and bolt openings on that side |
09-03-2021, 07:10 AM | #6 |
mTekMods
2142
Rep 2,901
not a bmw bolt, could have been used in liew of the original subframe bolts. The control arm bolts are larger.
Flyboidev16.50 |
09-03-2021, 07:23 AM | #7 | |||
Rep 1,069
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus |
09-03-2021, 07:26 AM | #9 |
Rep 215
all i remember was its the front left and was one bolt on top and right below they both same in length 4 inch bolt with a 6 side head 13mm. this is so annoying . after the camera if i still cant find it will say a prayer and start her up.
i remember i was on my back on the floor when i took them out. |
09-03-2021, 07:37 AM | #10 |
mTekMods
2142
Rep 2,901
why would someone remove the ac compressor to do rod bearings.
09-03-2021, 07:43 AM | #11 | |
Rep 1,069
Just trying to help, not trying to be critical of what he should or shouldn't, may or may not have removed.
09-03-2021, 01:34 PM | #12 |
Rep 215
i also did a oil housing gasket install and i removed them thinking it was holding the housing i should of put them back in once i realized i took them out for no reason
09-03-2021, 01:36 PM | #13 | ||
Rep 215
Dpc2u11503.00 |
09-03-2021, 11:46 PM | #14 |
Rep 215
that endoscope camera was a fail. i went over again and i the ac compressor has all its bolts. i took out all the pulleys and i dont see nothing on the left side. i came to the conclusion it had to be to be when i took the oil housing off because i had a hard time finding which bolts even after looking at the diy with the pictures. i dont think me dropping the subframe will make a difference in my search when i know its from somewhere in front of the engine. tomorrow is the big day and if anyone finds where the hell these bolts go ill cash app that person 30 bucks as a token of my appreciation. thanks!
09-06-2021, 05:35 AM | #15 | |
mTekMods
2142
Rep 2,901
this is the part number 07119905403
09-06-2021, 05:37 AM | #16 |
Rep 215
if thats true i owe you. im going outside now
omg hes right. it went right in. mad at myself for not being able to find it myself after spending so much time. thanks so much for your help. made my day. 😃 i think i took em out when i was looking for the bolts to take out the oil filter housing gasket job i did before the rod bearing job i did. thanks again |
09-07-2021, 10:57 AM | #17 | |
Rep 1,614
Angr238738.50 |
