04-01-2020, 11:29 PM | #2 |
Rep 234
BRNDNSLVRA904.50 |
04-03-2020, 04:37 PM | #6 | |
奈良シカマル
905
Rep 482
Because I decided to add it? Im sure its not louder than the exhaust so idk why youre complaining.
Meister Motoring in Ft Lauderdale! Quote:
Definitely a deeper tone. Id say its like, 35% louder. Maybe more. No drone whatsoever. It sounds amazing.
04-03-2020, 08:37 PM | #7 |
Rep 1,386
Drives: 06' E46 M3 ZCP
Sounds nice. Anyone know if the cat delete has been done to the perforated (two-pipe) pipe mod?
04-03-2020, 08:39 PM | #8 |
Rep 1,386
[QUOTE=954MM;25996846]Check it out:
any downside to the 2ndry cat delete? At the minimum I'd assume issues with emissions which isn't an issue in FL seeing as that you guys aren't required to have that done. |
04-03-2020, 09:55 PM | #9 |
Rep 234
05-30-2020, 10:03 PM | #10 |
Rep 940
Sounds amazing. For your vid you only replaced the 4 perforated pipes with straight pipes? Nothing else?
2013 e92 M3
2011 X5 35d 2018 F80 M3 ZCP |
06-01-2020, 07:16 AM | #12 |
Rep 10,595
It's freaking glorious man. I have the regular OEM mod and love it, but some more volume would be nice. Might do this over the summer.
06-01-2020, 11:19 AM | #14 |
mTekMods
2115
Rep 2,872
4 pipe mod is basically a muffler delete no?
your deleting all the perforated sections within the muffler, why not just delete the muffler and save the weight
06-01-2020, 12:00 PM | #16 | |
Rep 940
2 pipe mod is replacing the 2 large middle pipes with straight pipes. ACM is basically straight pipes through the exhaust which helps it drone less than straight pipes I guess. I think this is a little louder than the 4 pipe mod. I'm probably wrong.
2013 e92 M3
06-01-2020, 12:40 PM | #17 | ||
Rep 6,631
Nah the dog hair insulation stuff is normally kept. you got 2 pipe where the two larger perforated pipes are replaced with solid pipes. 2.5 where a third smaller perforated pipe is I think half replaced with solid or half wrapped with material that covers the holes. You could do other varieties I guess replacing half of the large pipes but I don't know of a name for something like that. 4 pipe replaces all 4 perforated pipes with solid in the center chambers. I understand the muffler design still reduces drone this way. ACM method which just bypasses the criss crossing of pipes in the center muffler and comes straight out so no pipes are going through the center where the "dog hair" is. This is going to have the most drone. |
08-14-2020, 04:36 PM | #18 |
Rep 59
This sounds amazing! I have the oem exhaust mod and want to get to this sound. When you remove the secondary cats do you have to add a straight pipe? Don't know how this stuff works. Also would any muffler shop be able to remove the secondary cats? What do I ask them to do? Lol
08-14-2020, 08:37 PM | #19 | |
Rep 234
08-14-2020, 11:10 PM | #20 |
Rep 59
I'm just trying to get a little bit more of a sound without compromising CEL or getting a tune, so thinking about doing this especially if it sounds even a little like yours.
08-15-2020, 12:08 AM | #21 | |
Rep 234
