08-01-2014, 10:13 AM | #1 |
Rep 692
Launch Control?
OK, so I turned off the DSC, EDC, put it in the fastest shift setting, hit the M button and couldn't get the "flag". Then I figured out I couldn't have my foot on the brake. Take foot off the brake, wala...launch control works (fun too). Here is my question. If you can't put your foot on the brake, how do you keep it from rolling forward, say out of the staging lights at the track? I know this isn't a 1/4 mile car, but doesn't seem to make sense that you can't use the brakes in conjunction with launch control. Am I missing something?
Thanks,
Dave [SIGPIC][/SIGPIC] |
08-01-2014, 01:46 PM | #3 |
Shrug
Rep 65
In general, DCT cars will not roll until you hit the gas unless you are on a slope. When you launch, you have to press the gas pedal all the way down, then release the shifter from the forward position that you holding and then the car launches. The diagram in the link below is accurate.
http://www.m3post.com/forums/showpos...42&postcount=9 Last edited by Galt?; 08-01-2014 at 01:50 PM.. Reason: accuracy! |
08-01-2014, 03:14 PM | #4 |
Rep 966
On a rhd car how do you hold gearstick forward while adjusting the launch rpm (also on left side of steering wheel). reach around the steering wheel? Nope. Spare left foot on the gear stick? Nope
Lol |
08-01-2014, 03:30 PM | #5 |
Rep 692
?? I put my foot to the floor and it sat at about 5500RPM. Let go of the shifter and was off. Didn't have to adjust anything on the steering wheel...
Thanks,
08-01-2014, 04:55 PM | #6 |
Rep 1,246
Once you get LC engaged you can lightly actuate the brake to stop it from moving forward.
08-01-2014, 04:55 PM | #7 |
Rep 1,246
Also, you can lower your launch RPM with your cruise control selector.
08-01-2014, 05:33 PM | #8 |
Rep 1,479
Drives: 2017 F80 M3
crypticc lives in the UK and drives a right hand drive, RHD, M3. The launch rpm can be adjusted by using the cruise controls stalk. Most believe the default launch rpm of 5,500 is too high, which creates a problem for those who own RHD M3s.
_______________________
1991 E30 M3/Brilliantrot 2017 F80 M3/AW |
08-01-2014, 06:22 PM | #9 |
Rep 966
It's the reason I've not tried this
08-01-2014, 08:16 PM | #10 |
Rep 692
Ah, didn't realize you could adjust the launch rpm that way. Learning more and more every day about this car. Love the technology. I'm auto crossing it tomorrow, so all this will come in handy. Really looking forward to putting it through some paces. Won't be able to use the power on an autox course, but it will be fun just the same...
Thanks,
08-01-2014, 11:23 PM | #11 |
Rep 1,577
I found out LC on a supercharged car is useless hahah. Immediately went sideways
2011.75 E90 ZCP DCT AW OEM CF splitters, mirror, and spoiler. Feeling so stock right about now.
08-02-2014, 12:18 AM | #12 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
Can someone with full bolt-ons recommend a good rpm to set it at?
08-02-2014, 12:46 PM | #13 | |
Rep 966
Meaning your car currently "thinks" it develops less torque than it actually does. And if that coefficient was adjusted it might compensate |
08-02-2014, 03:56 PM | #14 | ||
Rep 1,577
08-02-2014, 04:00 PM | #15 |
Rep 3,482
I bet it was tons of fun, though.
BMWCCA:518970 |
08-02-2014, 04:10 PM | #17 | |
Rep 1,577
08-02-2014, 04:59 PM | #18 |
Rep 547
08-04-2014, 03:13 PM | #20 |
Rep 2,982
What this car has shouldn't be called launch control. It should be called burnout mode. Using launch control does not effectively minimize wheel slip to put down only the power the tires can handle until the car is up to speed like real launch control on GT-R's and other exotics.
It just lets you sit there and burn out to no end. 9/10 times you'll probably launch slower by using LC. The best thing you can do is set suspension to soft to allow the tiniest bit of extra squat which equates to increased rear tire traction, stay in D5 mode with power button on and either mash the throttle or very quickly accelerate your foot down to allow the dct clutch to modulate itself properly. That tiny bit of lag you get when smashing down the pedal always seems to cause me to automatically lose half a car length right from the get go....a killer if you're only trying to street light race someone up to 50 mph or less. |
08-04-2014, 05:39 PM | #21 | |
Rep 268
Because you are not doing it right. This is why you change the launch RPM with the cruise stalk. I can launch perfectly using LC with 3500-4000, no burn out but a chirp and then go. |
