BPM
      09-19-2019, 01:32 PM   #1
BlackPhoenix
Drives: '12 E93 6MT VT2 625, JB/FR
What's up yall, hope this is in the right spot for this post.
My 2011 6MT E90 M3 is about to undergo some big upgrades, and I wanted to hear some of your experiences with any of these upgrades, mainly in terms of NVH/other issues. I recently got this car last December, after my 2011 VT650 E93 was totaled. So far it's undergone the following: Ohlins R/T, Dinan sway, AP Racing BBK, full aero/badges, Forgestar/295 PS4S, Corsa catback.
Here's what I have planned in a couple weeks:
Harrop SC, RKP(Challenge) Sport Xpipe, BayOptiks, Autosolutions SSK, solid subframe bushings, differential bushings, throttle actuators/other wear items.
Purpose: Car is currently my weekend/occ daily/roadtrip car and has not been to the track yet this year (will see COTA in November FTW). It will see more track time once I have work sorted out and finish my move. Goals are to keep extra NVH at a minimum, esp since it will be seeing a ton of roadtrips.
I'm pretty much settled on BW solid subframe bushings and Purple Powerflex bushings, with the thought of minimizing the diff whine that I read can happen at slow highway speeds (55-60mph). Def will need these to put down all that extra power. Not really interested in going to a much harder diff bushing, since this car will see regular roads as well. I'd prefer to hear the whine from the engine instead.
For those with AutoSSK and upgraded carrier and shifter bushings, what have you noticed in terms of gear noise/whine/vibration? Did you go with the stock bushings with the kit or elect for 80A, 95A upgrades? I got the OEM ones but considering the harder ones, likely 80A. Any annoying quirks like V/H in the stick shift? I'm electing for replacement of all the bushings here with OEM, but not sure since I'd like something more durable...
Sorry for the lengthy post, many thanks in advance for any advice!
And... the crappy iPhone teaser pic:
      09-19-2019, 04:37 PM   #2
nycplumber
Drives: slow
I had those on my last DCT and it was my favorite upgrade. I will do it on this car eventually as well. The whine wasn't really noticeable especially if you have a louder exhaust. I am either ripping it or have music on so the whine was basically non-existent.
      09-19-2019, 06:11 PM   #3
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
Drives: E90M/E92M/F80CS/X5 35/MiniCS
as long as you don't do hard diff bushings you are fine with the rest of the mods
      09-19-2019, 07:35 PM   #4
serranot
serranot's Avatar
202
Drives: 2011 E90 M3 6MT
2011 BMW E90 M3  [5.00]
I have the SSK. You might feel a tiny bit more vibration in your hand but that's it.
      09-19-2019, 10:30 PM   #5
dozaiya
Taiwan
176
Drives: 2011 MW E92 M3
im dct on solid subframe and purple diff, the whine only happens from 80km/h to 100km/h and it's a good type of whine i think you may actually enjoy it
i believe for a manual you can even go powerflex black and you should be fine
      09-19-2019, 11:02 PM   #6
Dave07997S
Drives: 2013 BMW M3 ZCP Coupe
Agreed the hard diffy bushings add a ton of nvh.
Dave
2013 M3 Coupe-MR/BLK ZCP, ACM test pipes, BPM Stg2 dev. tune and Megan catback, AFE Stg2. with C/F elbow VMRV810 19x10&19X11 275/295 Mich PSS.
Previous rides: 2011 M3 Coupe-MR/Blk
2007 Porsche 997C2S Speed Yellow/Blk sport seats
2004 BMW M3 Imola/Blk
SYT_Shadow4072.00
      09-20-2019, 01:04 AM   #7
gte869h
Upgraded from e46fanatics
gte869h's Avatar
Drives: 2011 BMW M3 6MT ZCP
Had to check my build sheet its been so long ago....
Powerflex front tension arm (thrust rod) bushing set
Powerflex high durometer rear subframe mount kit
Powerflex black series M3 differential mount kit
Zero issues with NVH on my 4.6L 6MT
Next set of mods Bimmerworld Tri-Y Headers, YCW Carbon Driveshaft, 4.10 Gears w/ Wavetrac LSD....Karbonius intake when it arrives.
Kudos on the Harrop bro, if I do another S65 will go that route for a change up.
      09-20-2019, 10:02 AM   #8
BlackPhoenix
Thank you, that's what I've read from other people's experiences...
Thanks did you
Awesome to hear, I'll start with purple and see how that goes I think.
Dave
Thanks Dave!
Wow sounds like a sick build! Im considering the front tension arms too while it's up on the rack. From what I've read, steering feels more precise. Any added steering wheel vibration from this setup?
Thanks again guys
      09-20-2019, 10:16 AM   #9
nycplumber
Drives: slow
@BlackPhoenix look at the Germam Auto Solution monoballs. Best design and the best price.
      10-05-2019, 06:05 PM   #10
gte869h
gte869h's Avatar
Sorry for delayed response, yes steering precise with the tension arm upgrade. No vibrations from the setup. But I have replaced worn front bearings and run race pads. The slightest slop or brake issues will come through the steering wheel.
      10-13-2019, 05:04 PM   #11
shuggy
shuggy's Avatar
26
Drives: 2011 E90 M3, Space Gray
I have solid on subframe, CF driveshaft, and purple on diff. The whine is most noticeable between 75-82 mph in 7th gear. I'd say about ~10% increase in NVH. It's slightly annoying because it's highway cruising speed.
MPE, tear pipes, and intake noise can't really mask it at stable throttle during hwy cruising, so if you want peace, gotta turn up the audio.
Other NVH increase during normal street driving below 65 mph is hardly noticeable. There's noise, but it's a subtle, mechanical noise that's quite sporty.
Since these mods were installed together, I cannot single out the main culprit, but from what I'm reading, I believe it's the stiffer diff bushings.
By the way, since you're planning on tracking, you'll have an excuse to get aggressive tires. My RE-71's are pretty loud on most pavement. It used to annoy me vs. RE-11's which were very quiet. Now I don't mind them as much because it helps reduce the diff whine.
2011 E90 M3 | Space Gray | All MPerf CF Trim | BMW MPE v2 | MS Test Pipes, Subframe | ESS Tune | MFactory CF DS | Eventuri Plenum | DINAN Intake, Pulley, Front Sway, Camber | H&R Rear Sway | Powerflex Diff | OEM EU Front Bumper, Visor, Rear Fog Switch | Huper Optik 65% | Potenza RE-71R | LUX H8 v5
2020 Range Rover Sport SVR (ordered)
      11-20-2019, 01:40 AM   #12
DRLane
DRLane's Avatar
96
I feel like the wine from the harrop is going to drown out any potential while from the diff.
I have solid diff bushings with subframe, CF driveshaft, and Ron's ssk with 95a bushings. It's all very manageable as daily.
Only experiment I reversed were AKG 95a trans mounts, those were insanely loud. Went with rev shift 80a Mounts and they're perfect.
      11-20-2019, 04:20 PM   #13
BPMSport
BPMSport's Avatar
Drives: Harrop M3 / F10 M5 / F82 M4
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [3.75]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
We went with solid subframe bushings and urethane diff bushings. The difference from the solid subframe bushings is unnoticeable. Solid diff bushings do cause some unwanted noise, while the urethane ones almost unnoticeably increase the sound levels. This provides the best of both worlds.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      11-20-2019, 08:58 PM   #14
BlackPhoenix
Thank you all for sharing your experiences. Just got the car back last week. Woah! What a difference!! Ended up with solid subframe, purple diffs, and OEM SSK bushings, rear trailing arms (to help with that extra power as was recommended to me) and GAS monoballs. The car def feels more planted and steering more precise. Shifting feel is much improved and precise, love it. Can't wait to get it on the track.
No noticeable V/H, but the whine, oh man, that Harrop is something else. Such a different character from the 650 kit on my last E93. Loving the low end torque. Beast. Mike and BPM, props for all the work you put towards this kit. Need to put much more time on it, but so far loving it. I'm sure Stage 2 will be even more of a hoot!
DRLane95.50
      11-20-2019, 09:53 PM   #15
DRLane
DRLane's Avatar
96
So awesome!
I'd like to hear how the SC fairs on the track. I'll definitely be joining the Harrop club.
Also, videos would be most appreciated. There's a serious lack of Harrop e9x M videos...
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
