Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Suspension | Brakes | Chassis | Handling
      08-12-2024, 12:34 PM   #1
IND-Distribution
IND-Distribution's Avatar
9842
Drives: G82 M4 / G87 M2
IND | Evolve Performance E9X M3 Damptronic Shock Absorber Set
Evolve Automotive developed these dampers in conjunction with Bilstein UK over a period of years. As good as the original Bilstein dampers were, they wanted to tailor them for use with lowering springs and MSS Height Adjustable Springs.
Evolve worked with Bilstein to change the valving to make the Comfort setting even more compliant and the Sport + setting slightly stiffer giving more range of damping given by the electronic modes in the EDC equipped E90, E92 and E93 M3
Not only that but a common complaint for all B6/B8 dampers is that they lift the front slightly. This wasn't something Evolve wanted so with a lot of back and forth with Bilstein they have developed a slightly shorter damper body that solves this issue. (some lift may be evident when brand new comparing to a used damper due to the nature of how Bilstein uses a gas pressurized damper)
Not compatible with KW HAS/BMW M Performance HAS.MSS compatible.
The Evolve Performance E9X M3 Damptronic Shock Absorber Set
may be viewed at the following link to our online store:
https://ind-distribution.com/product...k-absorber-set
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
Search this Thread:
Advanced Search
