Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Suspension | Brakes | Chassis | Handling
      08-01-2024, 06:04 AM   #1
paulh@evolve
paulh@evolve's Avatar
United Kingdom
119
Drives: All BMW models
Location: Unit 32 Sundon Industrial Estate Dencora Way Luton Bedfordshire LU3 3HP
Arrow EVOLVE | E92 M3 Evolve x Bilstein Damptronic Shocks
The Evolve x Bilstein Damptronic Shocks for the E92 M3
We have developed these dampers in conjunction with Bilstein UK over a period of years. As good as the original Bilstein dampers were, we wanted to tailor them for use with lowering springs and MSS Height Adjustable Springs.
We worked with Bilstein to change the valving to make the Comfort setting even more compliant and the Sport + setting slightly stiffer giving more range of damping given by the electronic modes in the EDC equipped E90, E92 and E93 M3
Not only that but a common complaint for all B6/B8 dampers is that they lift the front slightly. This wasn't something we wanted so with a lot of back and forth with Bilstein we have developed a slightly shorter damper body that solves this issue. (some lift may be evident when brand new comparing to a used damper due to the nature of how Bilstein uses a gas pressurised damper)
These dampers can be used with stock or any lowering springs on the market that work with stock dampers, including MSS Adjustable Springs. They will not work with KW HAS/BMW M Performance HAS.
We run these dampers with MSS springs on our own demo E92 M3 and the ride and handling characteristics are the best we've tested on this platform.
Watch the video review below to learn more!
Click Here to view the product
      08-06-2024, 01:57 PM   #2
OmairK
Engineer
Drives: 1995 M3 - 2011 E90 M3 6M ZCP
Paul, can you give us the parts list needed to complete the front and rear suspension install? What is the inner diameter of the MSS springs?
      08-07-2024, 03:20 AM   #3
paulh@evolve
United Kingdom
119
The parts required are below:
MSS Suspension - E9X M3
Evolve X Bilstein Dampers - E9X M3
I have requested the inner diameter detail from MSS
      08-13-2024, 07:18 AM   #4
paulh@evolve
United Kingdom
119
Just to follow up on this, from MSS:
From 95mm at open end to 110mm at the grounded end for the front and 60mm for rear orange and 64mm for rear black
      08-14-2024, 07:55 AM   #5
paulh@evolve
United Kingdom
119
      08-28-2024, 05:38 AM   #6
paulh@evolve
United Kingdom
119
Still our most popular product, get in touch today!
      09-17-2024, 05:23 AM   #7
paulh@evolve
United Kingdom
119
Tags
damptronic, shock absorbers, shocks
Search this Thread:
Advanced Search
