04-03-2023, 12:10 PM | #1 |
Rep 243
Pinched Wire causing gauge cluster failure?
Got a weird one for you guys. Haven't done any troubleshooting yet but I have a question...
The symptoms:I am getting code U112B which is a instrument cluster failure code. Car runs and drives totally fine, but every minute or two all the dash lights come on/instrument cluster freaks out. Also none of the idrive scroll or buttons work. All goes back to normal after about 10-20 seconds (except CEL for the aforementioned code, and still no use of idrive). Only seems to do this while moving, once I stop at a light or something I can use iDrive again, and the dash doesn't freak out. Tentative cause: On Saturday I washed my car very thoroughly, spraying a lot of water at all angles. And then I installed Mr12volt unit. During install I cracked the OEM clip in the center console that plugs into the iDrive controls. And possibly pinched one of the wires. The Question:Would just a cracked clip/pinched wire at iDrive controls cause the whole dash to freak out like that? If so, why would it only start once I start moving? When I first start up the car, everything works normally. Or, is there something sensitive that I bumped elsewhere? I installed the mr12olt back by the fuse panel behind the glovebox. Could be hitting something... I know all these components are interconnected, just wanted to see if anyone else was getting all these Christmas lights from just a pinched wire somewhere. Or if it's something else causing this.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package Last edited by Thumbie; 04-03-2023 at 12:16 PM.. |
04-04-2023, 10:29 AM | #2 |
Rep 243
Update: that wasn't it. Rechecked all connections and cleared all codes. Now it all works fine but I have a low tire warning and I can't reset TPMS. I read somewhere it is a module failure that can cause this? Will do more digging on that.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package |
06-19-2023, 11:45 AM | #3 |
Rep 243
Late Update: I am pretty sure it's the mr12volt unit. It's too much of a coincidence not to be. The problem went away for a while but now is happening almost constantly. I am going to check all fuses. How do you check relays?
-Thumbie
06-21-2023, 01:39 PM | #5 |
Rep 243
It takes power from the headunit, and that is connected by the large clip so I can't isolate power without cutting the most loop. I may need to try again reverting back to stock. I did once before and all seemed to work fine.
-Thumbie
