03-04-2021, 05:20 AM | #1 |
Rep 108
Lighter battery option - B
Just wanted to report, that lighter 60Ah S5 A05 BOSCH AGM 60AH TYPE 027 S5A05 works absolutely well on my M3 E92. I have used it about full year, through the cold winter. Started my car at -10C (14°F), no problems and no errors.
Li-Ion car batteries cost roughly 1000 € and weight ca 3 kg or so. I did not go to this direction in my weight reduction progress. Instead, I chose more economic way to switch heavy 95 Ah lead acid battery to 60 Ah battery. Before: 95 Ah; 26 Kg After: 60 Ah; 16 Kg Weight savings: 10 Kg
M3 E92 ZCP LCI
03-04-2021, 10:59 AM | #2 |
///M Powered for Life
11487
Rep 10,329
That's a pretty good weight delta for a reasonable price!
Expressivedrives249.00 |
03-16-2021, 05:29 AM | #3 | |
Rep 259
Have you had any problem in that regard? Thank you
Instagram: @m_rochen
Alpinemss Tuned | Tecnocraft E9X ///M3 Envy™ Intake System | MS Pulleys | Akrapovic Evolution Exhaust | Ohlins Road&track| BBK Brembo 6p Front & Brembo 4p Rear| H&R Stabilisator| Solid subframe bushings| full spherical bushings| Recaro pole position |
03-16-2021, 05:52 AM | #4 |
Rep 108
Hi Rochen
I use Ctek MXS 5.0 when I know that cars sits longer time. But 2 weeks was no problem. Happened few times.
M3 E92 ZCP LCI
