  TireRack
      03-10-2015, 12:39 PM   #1
m3aviator
m3aviator's Avatar
Drives: BMWs
Super lap offsets
Have an opportunity to get a set 18x9.5 18x11+34. How should I expect these to fit in the rear? Gonna run 265/285. Thanks!
      03-10-2015, 12:48 PM   #2
BenSopra Motorsport
Drives: F8X M3/M4, F10 M5
2015 BMW F10 M5  [0.00]
2015 BMW F83 M4  [0.00]
2015 BMW F82 M4  [0.00]
2015 BMW F80 M3  [0.00]
Front:
265 - 285 no problem. even 295 too but probably a little too much tires for the 9.5 rims.
Rear:
285 and 295 will be no problem for the rears.
I think 305 should fit as well.
      03-10-2015, 01:29 PM   #3
m3aviator
m3aviator's Avatar
Drives: BMWs
I know the tires will fit I was asking about the offset in the rear.
      03-10-2015, 01:44 PM   #4
CIFUM3
CIFUM3's Avatar
Drives: 08 E92 M3
I'm running a 19x11+33 with a 305/30 with no rubbing what's so ever idk if that helps
Performance
ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe
Looks
M colors grill - CF trunk - Sapphire Blue Forgestars F14
      03-10-2015, 01:51 PM   #5
m3aviator
m3aviator's Avatar
Drives: BMWs
My apologies I guess I should have been more specific. +34 in the rear will fit flush in the rear or still need a spacer? Thanks!
      03-10-2015, 02:06 PM   #6
steven_s
Drives: M3
Depends on your set up.
I know on KW v3/CS it definitely won't fit. x10.5+20 is already pretty flush and 295/35 will give you an occasional rub. I can't speak for yoru HR springs
x11+34 is 20.4mm closer to the suspension strut. The outer rim will poke out 7.7mm less than before
      03-10-2015, 03:08 PM   #7
m3aviator
m3aviator's Avatar
Drives: BMWs
Thanks!
      03-10-2015, 05:11 PM   #8
Hujan
Hujan's Avatar
Drives: M3
Are you talking about TE-37 SL? Was not aware they made an 18 x 11" et 34
      03-10-2015, 06:52 PM   #9
steven_s
Drives: M3
it's not. it's a fitment that was made to order for the f80
i think even with smaller linear springs swapped in the rear ala eibach or swift you'd still find it hard if not impossible to fit that. that's a full inch closer to the strut. we're talking 18s. 19s i think is doable.
      03-10-2015, 07:28 PM   #10
m3aviator
m3aviator's Avatar
Drives: BMWs
Steven thanks for the save owe you a beer!
      03-12-2015, 03:21 AM   #11
squartus
Drives: 2010 E92 M3 6MT
2010 E92 BMW M3  [10.00]
I have 315s in the rear with 33ET, fits flush. Also have some te37 sl's coming it with 315,s on as well so will see how that looks.
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc
      03-12-2015, 08:35 AM   #12
steven_s
Drives: M3
Are you talking 18s or 19s.
19s can run that set up.
And what are you lowered on.
      03-12-2015, 10:07 AM   #13
Hujan
Hujan's Avatar
Drives: M3
Are you talking about a rub on the inner or outer side on the boldfaced setup? I can see how 11" et 34 might rub on the strut (inner), but I can't see how 10.5" et 20 would. On a 10.5" et 20 with a 295 tire, the concern would be rubbing on the fender (outer) depending on what tires you fit.
I am thinking an 18 x 11" et 34 with a 295/35-18 tire and a 5 mm spacer would be pretty dialed for both inner and outer clearances. Hmmm.
I'm almost afraid to ask, but does anyone have a link to where the 18 x 11" et 34 is available?
      03-12-2015, 10:43 AM   #14
steven_s
Drives: M3
Talking about the inner strut. If anything call on slicer, he's had and done it all. Maybe I'm mistaken.
He had x11 +25 and I believe that was already pushing it. +34 is making it 9mm closer to the strut.
The 18x11+34 is from Ben Sopra above.
      03-12-2015, 12:29 PM   #15
m3aviator
m3aviator's Avatar
Drives: BMWs
Would +34 fit with a sleeve kit?
      04-16-2015, 06:35 PM   #16
m3aviator
m3aviator's Avatar
Drives: BMWs
Bumping this thread. Will 18x11 +34 inner diameter clear the shock? Can a spacer be run to increase inner diameter without the outer being past the fender?
Thanks!
      04-16-2015, 08:10 PM   #17
squartus
I had an 20x11 et 33 and it cleared everything ok with 315's, back to 18's now though.
