| 10-20-2017, 10:09 PM | #1 |
![]() ![]() ![]() ![]() 383
Rep 800
headlight condensation
So I washed my car this afternoon. I used the foam canon and then rinsed with the power washer. I noted this late tonight on the passenger side headlight (inside).
Any ideas on how to prevent this?
| 10-26-2017, 01:21 PM | #2 |
Rep 7,623
There is a hatch inside the fender for the turn signal. If I go to aggressive with the water pressure inside the fender I get what you do. Easy fix by open the headlight lid (under bonnet) and let dry put while finishing up after wash.
carenthuziast383.00 |
| 10-26-2017, 01:33 PM | #3 | |
Rep 800
Also, I did something as simple as spray a water bottle with glide in it and the inside also got fogged. Crazy that the headlight is so susceptible to moisture.
| 10-26-2017, 02:56 PM | #4 | |
General
![]() ![]() ![]() ![]() ![]() 90547
Rep 30,872
After 30 SEC. it's gone...Piece of cake and fixed !
| 10-26-2017, 02:58 PM | #5 |
Master Baiter
4160
Rep 628
Drives: 09 Z06
There are multiple covers in the BMW headlights. If you recently had them open to change a bulb, check the seals. One may be out of place allowing moisture in.
| 10-27-2017, 09:34 AM | #6 | |
Rep 800
I've had my E93 since June 2013 and haven't messed with it much other than driving it and washing it recently.
| 10-29-2017, 03:17 PM | #7 |
Rep 7,623
Have a look here:
blog.bavauto.com/10975/bmw-diy-angel-eye-led-bulb-upgrade-install-how-to-e92-e93-and-m3-3-series/ |
| 10-30-2017, 01:04 PM | #8 |
Rep 832
Same problem here, open the hatch to the angel eyes when you pop the hood. Turn on your headlights for 15 mins with the hatch open. When you close the hatch make sure it’s sealed and the condensation should go away.
Worked for everyone I’ve told with this problem. |
| 09-13-2024, 10:47 AM | #9 |
Rep 1
I get Condensation in this headlight. My question is why would the halo ring not light up ?? The high and low beam works just not the ring… do I need a new unit or can it be somthing else ??? New Beamer owner….
| 10-07-2024, 03:01 PM | #11 |
Rep 7,623
The halo ring is powered with a separat lamp bulb. If you open the top hatch you'll be able to see the wires going through a ballast, my guess is either this or the buld need to be replaced. A straight forward job that doesn't require more opening than mentioned hatch.
| 10-07-2024, 07:01 PM | #12 |
![]() 5007
Rep 4,830
The headlight unit has several bulb covers - one big triangular one on top, and several in the back. At one point I was dealing with headlight condensation only to find out that one of the turn signal bulb covers was missing. So check all your covers. If the seals are not damaged/torn, recondition them with some silicone spray.
| 02-03-2026, 09:39 PM | #13 |
Rep 11
Headlight water marks
I've got drip lines on the inside of my headlights. Would anyone know how to remove them and prevent them happening again? Thanks
photo: https://ibb.co/v41Rz5Vr |
| Bookmarks |
| Thread Tools | |
