10-21-2014, 03:25 PM | #1 |
Rep 923
engine dying
Engine is going into limp mode, dies, and gives out an "increase emissions" message. I try to restart it and it sounds like its running rough, eventually starts sounding normal with limp mode still activated. It keeps shutting off so i cant even bring it to my shop. I have no more warranty so it seems im pretty fucked, but does anyone have a rough idea what it could be? Trying to prepare for the worst.
10-21-2014, 04:05 PM | #3 |
Rep 1,133
Drives: 2008 Jet Black M3 Coupe
Throttle actuator? SCAN IT!! easy to fix if that's it
10-21-2014, 04:20 PM | #4 |
Rep 7,542
If it's shutting off it's probably not a throttle actuator - sounds like a bad crank sensor to me.
10-21-2014, 07:42 PM | #6 |
689
Rep 6,854
Check engine lights? You have the codes??
-Anthony
Travis Williams
Shop ALL BMW G80 | G82 Parts Here! 480.966.3040 ext 318 Travisw@vividracing.com PM, Email, or Call Directly for aggressive BMW Member Pricing |
10-21-2014, 08:07 PM | #7 |
Rep 3,456
Drives: Harrop E90 M3
Stalling is likely an idle control valve issue. Codes are needed to know for sure though.
10-21-2014, 09:20 PM | #8 |
Rep 816
It's all a stab in the dark until he gets the codes read.
RocketyMan230.50 |
10-21-2014, 10:04 PM | #10 |
Rep 164
Sounds like rod bearings to me
JPSurratt200593.00 |
10-21-2014, 10:06 PM | #11 |
Rep 6,149
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
10-22-2014, 08:28 AM | #12 |
Rep 923
Im going to have to get it towed to the shop later today to pull the codes, just wondering someone out there experienced this problem. Its not throttle actuators as they are new. I'll ask the shop to check the crank sensor, thanks mike.
10-23-2014, 08:35 PM | #13 |
Rep 923
My shop couldnt find a definite solution even dealing with the tech info from autologic. They did reset the ecu adaptations and it drives really good now and better than it did before these problems manifested. No limp mode or engine stalls on the way home. I do have a persistent error code for the map sensor (i had it for last two times i pulled codes after going into limp mode), which they ordered one just in case it happens again. Here are the error codes for people wondering-
CDB7 (Had edc coded out) 27AB- charge plausibility, diagnosis hot - bank 2 27AA- charge plausibility, diagnosis hot - bank 1 2738- charge plausibility, diagnosis, cold-start strategy, bank 2 2B0D- idle actuator monitoring, bank 1 2714- intake-manifold pressure sensor 2B29- moment manager monitoring |
10-27-2014, 11:04 AM | #14 |
Rep 923
Well it didnt fixed it! It went into limp mode this morning with dsc malfunction so i turned it off and started it back up. Ran rough like it did before.
12-29-2014, 03:07 PM | #15 |
Rep 923
Well its been over a month since i replaced the map sensor and it ran fine. Until last week i got the same symptoms. I pulled the codes today and i got the same error codes as before. I changed the idle control valve and the map sensor already and i am lost on what to do.
12-29-2014, 03:35 PM | #16 | |
General
63966
Rep 24,837
12-29-2014, 03:51 PM | #17 |
Rep 923
12-29-2014, 05:13 PM | #18 |
General
63966
Rep 24,837
Indeed, the reputation of most are
03-06-2015, 08:31 AM | #19 | |
Rep 71
Also replaced the map, after replacing the idle actuator and the sensor on it, didnt help My dealer suggested to change one of the lambda sensors, but I can not really understand the link between them...
03-06-2015, 02:07 PM | #20 |
Rep 923
Im getting a smoke test done this friday thinking it could be vacuum leak within the system. Thinking a leak could cause it go lean, I'll give you a heads up. Thats weird considering the dealer should know that there is a specific code for a bad lambda sensor.
03-06-2015, 02:15 PM | #21 |
Rep 241
Drives: 2011 E93 M3
I'm betting it's the ICV, I just changed mine out. Turned out it was something else. Checking if my shop still has the old one.
2013 F10 M5/TTFS CUSTOM TUNE/PURE S1 TURBOS/METH/AMS CL DPS/RPI CATBACK/KW SLEEVE OVERS/RPK FRONT LIP/M PERF REAR SPOILER/20" LOMA SUPERTEC SUPERLIGHTS
03-09-2015, 04:13 AM | #22 | |
Rep 71
I have heard that after each removal of the intake plenum we have to change those eight fasteners holding it within throttle bodies. I have removed it three times already. May be this gives that leak... Concerning the lambda, there may be some link between them, they both work on controlling the fuel/air mixture. Please let us know the results you will be given
