E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > BMW 328xi e90 n52 x drive malfunction HELP!@!
      04-24-2024, 03:11 PM   #1
Dontownane90
Drives: E46 2004 330ci (ISO E90 parts)
Exclamation BMW 328xi e90 n52 x drive malfunction HELP!@!
Hello,
I have a 2011 328xi, I bought it with x drive issues.
I am assuming it’s the transfer case actuator based off the codes, after resetting the oil life and resetting adaptations on the transmission and transfer case, these codes return.
Would I need to clear the remaining oil life code using ISTA + and repair the T case actuator?
Any help is appreciated.
Thx.
      04-24-2024, 05:08 PM   #2
gbalthrop
Drives: 2007 328xi E91
Originally Posted by Dontownane90 View Post
... 2011 328xi, I bought it with x drive issues...
Questions:
1) What Make/Model Scan Tool or Diagnostic Software (INPA/ISTA) do you have?
2) What Warning Lights appear on Instrument Cluster when driving?
3) Remove Fuse F40 (30A) and test it electrically as well as visually. That is fuse supplying power to VTG/ Actuator.
4) Performance & Warning Lights SAME since you bought it?
5) Last-7 Characters of VIN?
George
      05-01-2024, 09:34 PM   #3
Dontownane90
Hi @gbalthrop,
Sorry for the delay, it’s been a very busy week and if not had time to compile the information.
But here we go.
1. Currently, I do not have working version of ISTA+, I’ve downloaded torrents and mega files however was unable to get either to work. So I am using THOR + Protool, or an Ancel BM500 bmw code scanner.
2. ABS, TRACTION, 4x4, engine light,
3. Will attempt this tomorrow!
4. Performance, abit better as I’ve had an exhaust leak repaired & cleaned the air filter. Still sluggish and no xDrive.
5.F196934
      05-01-2024, 09:48 PM   #4
Dontownane90
I actually went ahead and changed out the T case actuator today, it did not solve the issue. And the actuator actually looked fairly new and better than the one I replaced it with from a knock working transfer case.
Have some new codes coming up, not sure if it’s to do with the work performed. Doubtful, as I did everything myself and had no issues with removal or install of the new tc actuator. Everything plugged in and bolted back up no problem.
They seem all to be related to front wheel speed sensor signals…
A0B5
5E4E
5E24
581A
581B
e90post
