05-31-2022, 03:38 PM | #1 |
Rep 635
I have been in and out of this project for almost 2 years. And finally seeing the light at the end. I wanted to build something that would allow case pressure to escape faster, not recirculate burned gasses oil and what not back though the intake, and lastly remove a wearable part with something you would never need to replace again. Wanted something that would hopefully help increase power, and extend rings and gaskets for our S65 engine. I have toyed with different designs but settled on more of a factory plate design. I've posted here and there on FB and my IG page but figured Id start a thread here to get feedback etc. I will be making a small run of these to help offset the project and there will be more info on that after testing. But anyway I thought I would share where I'm at now.
I am currently working on a factory mounting point bracket for the catch can and once that is complete it will be ready for testing. Flame away! [IMG]https://i.ibb.co/ws2F4Qp/284709042-1...65919018-n.jpg[/IMG] [IMG]https://i.ibb.co/6N6S0GL/284853247-1...81843134-n.jpg[/IMG] [IMG]https://i.ibb.co/MR9dnrF/284425326-1...58219508-n.jpg[/IMG] [IMG]https://i.ibb.co/x6jnTxx/283951656-1...93382843-n.jpg[/IMG] [IMG]https://i.ibb.co/YWpY4hm/284564958-1...90980764-n.jpg[/IMG] [IMG]https://i.ibb.co/gPhnDb0/284776538-1...34522272-n.jpg[/IMG] |
SilverSlug680.00 DRLane3988.50 Davisca4552207.50 Carbon_fibberm317.00 KawBoy154.50 Bmwdoubles_194.00 DrFerry6728.50 |
05-31-2022, 03:49 PM | #3 | |
Rep 635
The catch can has a valve and a line that you turn to drain out the end of where ever you route the line to. |
SilverSlug680.00 DrFerry6728.50 |
05-31-2022, 04:47 PM | #6 |
Hey, where have you been all my life?
680
Rep 1,401
05-31-2022, 05:04 PM | #7 | |
Rep 3,411
In this case, my intention would be not to recirculate oily air back into the intake period. Id also like to delete the secondary air pump. These are emissions components which are essential for street application. My build continues to march in the direction of track only and thus I'd like to remove all extraneous parts to simplify and streamline the bay. I'm not there yet, but a well machined piece is one less item I need to have made. Make sense?
05-31-2022, 05:14 PM | #8 |
680
Rep 1,401
Almost makes sense… Saying that in this case, the intention is not to recirculate oily air back into the intake, but that's what a catch can is for… to filter that air, so it wouldn't be oily.
Is this working under the presumption that an oil catch can will not filter all of the oil out of the air? |
05-31-2022, 05:50 PM | #9 | |
Rep 3,411
I'm deleting the recirculation.
05-31-2022, 05:54 PM | #10 | |
Rep 635
As for the catch can it could be completely up to you on how to route this. You can route from these plates to your catch can back into your plenum. You can route from your catch can to atmosphere, or you can route from your catch can to your exhaust creating suction on the system. The lines are 10an and will give ample breathing to your engine, not allowing much or any pressure to build. The Nuke catch can has an internal filter and the ability to run an exit line out. Yes this is intended for racecar or off road use and is a product that is intended to remove epa products factory installed on your car. So do what you wish. For me I don't want exhaust gasses etc being rerouted back into my intake. I don't want any pressure in my case that would cause wear either on my rings or gaskets. I don't have an issue with burning oil but this could solve that as well. And lastly it will look much better and clean up the look at the end of the day. It was just a project that intrigued me from years ago posts and pictures of race cars running the s65 engine with no oil separators. Hopefully soon I'll be able to do some testing and report more info. I plan on running a base run on the dyno this Saturday and going from there. Feel free to ask questions. I'm no astrophysicist, just an airline pilot that loves my car and always looking to improve the driving experience. |
05-31-2022, 06:02 PM | #11 |
680
Rep 1,401
Thanks for the details.
I remember you talking about this years ago, and I believe your initial plan was to route it into the exhaust, no? It's cool to see how it has evolved. Will installing this trigger a check engine like OBD code? Still pass smog? |
05-31-2022, 06:07 PM | #12 |
Rep 635
It should not trigger anything as there is no sensor in the oil separator
SilverSlug680.00 |
05-31-2022, 06:22 PM | #14 |
Rep 4,167
Looks interesting. What about the hole on the plenum side?
SilverSlug680.00 |
05-31-2022, 06:27 PM | #15 |
Rep 635
SilverSlug680.00 |
05-31-2022, 06:29 PM | #16 |
Rep 635
SilverSlug680.00 |
05-31-2022, 06:46 PM | #17 | |
680
Rep 1,401
Impressive to see the progress moving along. Please keep us posted. |
05-31-2022, 08:34 PM | #20 |
Rep 635
05-31-2022, 08:46 PM | #21 |
Rep 25
Then put me down if it shows to be beneficial and works seamlessly then I definitely want one
06-01-2022, 10:29 AM | #22 | |
Rep 675
Dinan Stg II Suspension • Remus Race • Gintani CF lip / CF quarter fins • Vorsteiner Type II CF Diffuser • BMW Performance CF Spoiler / black fender gills / black kidney grilles / CF mirror cover • Speed Element GTS CF side skirts • M3 GTS door sills • Lux Angel Eyes • body color reflectors • Alex@Alpine Stg I tune • AA filter
