      02-05-2017, 10:57 AM   #1
RomanK
Russia
46
Drives: M3 Coupe E92 DCT
Idle Control Valve?
Hello guys.
Today I have Check Engine light and limp mode. After restarting of engine the Check Engine light and limp mode appears again right after the starting.
I read the error codes and I have the next:
DME:
2B0D - Idle actuator monitoring, bank 1
2B57 - DME: Air-mass sensor, plausibility
2714 - Intake-manifold pressure sensor
2796 - Throttle: adaptation values incorrect
DSC:
5E19 - CAN DME/DDE, engine torque not adjustable
Does it mean that I should change the ICV? I need to be sure because ICV is so expensive. Is there a way to repair my ICV? Can I rinse or blow it?
After when I deleted all error codes and started the engine - it worked fine. But I didn't drive my car after that today. Maybe it appears again.
Thank you for any help.
      02-05-2017, 10:58 AM   #2
RomanK
Russia
46
I so sorry, please, moderator, move this thread to correct forum. Sorry for my mistake.
      04-10-2017, 09:19 PM   #3
Titan_br
Titan_br's Avatar
Brazil
12
Drives: M3 E92 with AA Stage 3 SC
2011 BMW M3  [0.00]
I have this too. But the car does not turn on, only if I unplug and plug the battery.
DSC:
What does this mean?
      04-11-2017, 06:22 AM   #4
Matheus
Matheus's Avatar
Brazil
23
Drives: 2012 M3 E92 Fire Orange
Originally Posted by RomanK View Post
Hello guys.
DME:
DSC:
I got this same problem a few months ago, right after I installed my SC. The car did not turn on, only if I press the gas pedal. Very erratic idle. Then, those erros appeared on the acreen and in diagnoses.
I took of the manifold and my mechanic took a look at the idle control valve. Ended up that it was stucked somehow. He said that he cleaned it, and everything was back to normal.
I don't understand much about this, but that was what my mechanic told me.
Good luck man, hope you don't have to change it.
      07-19-2018, 02:14 PM   #5
Titan_br
Titan_br's Avatar
Brazil
12
2011 BMW M3  [0.00]
Anyone has a picture of location of ICV?
      07-20-2018, 10:32 AM   #6
M3_92101
Drives: 2008 E93
These should give a pretty good idea.
      07-20-2018, 10:36 AM   #7
svinfinity
Drives: E92 JEREZ M3
How much of a pain in the ass is it to remove that center wire harness?
      07-21-2018, 08:38 AM   #8
last1left
last1left's Avatar
175
Drives: e92 M3
Super easy to remove harness.
      07-21-2018, 10:07 AM   #9
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
You can probably try to clean the mechanical part of the ICV, we used to service them on then E36 m3’s back in the day.
      07-21-2018, 01:43 PM   #10
svinfinity
Do you remove the air pump connected with it in the rear? I’ve only disconnected wires and remove the 4 bolts to lift up just enough to replace throttle actuators
      07-21-2018, 01:48 PM   #11
last1left
last1left's Avatar
175
Drives: e92 M3
Yes
