      05-30-2021, 10:55 AM   #1
grsd03
Drives: 2011 M3 Conv.
EDC button not working with new module
Recently replaced my dead EDC module on my M3 with a new one. It fixed the problem of draining the battery but now my EDC button doesn't work.
Only works (lights up) if I hit the M button on the steering wheel.
The DSC and power button both work around it when I press them.
All I did was plug it in during replacement. Was there a software side of things I was supposed to update?
Thanks.
      05-30-2021, 01:49 PM   #2
crowtrobot
Drives: 2008 M3
If I recall correctly, I had to reflash the EDC module with NCSExpert when I replaced mine.
Try writing a blank .man file to the EDC module with the sg_codieren function.
      05-31-2021, 08:25 AM   #3
grsd03
Thanks.
Haven't done that before so will have to look it up. Do you have any links or steps you can provide for doing this?
      06-02-2021, 10:47 AM   #4
crowtrobot
Drives: 2008 M3
Originally Posted by grsd03 View Post
Thanks.
You'll need a KDCAN cable, I got mine from bimmergeeks. I had a cheap amazon one, which worked with my E8x, but not my E9x.
The BMW software package is also available from bimmergeeks.
I don't have a step-by-step instruction set, but if you google or search youtube for coding an E90 with NCSExpert, you should get a clear picture for what to do.
      03-30-2023, 06:25 AM   #5
Adam M
Drives: BMW e92 M3
Can anyone help me out here?
My edc button is showing the same behavior.
It works with the m button but cannot change settings.
Can change settings by reconfiguring the m button in the menu.
Other two buttons on the panel work fine.
I have not bought a new edc module, just noticed this behavior from the button.
