  TireRack
      04-02-2021, 06:54 PM   #1
DL335D
DL335D's Avatar
580
Drives: 2013 e92 M3 Q4
I just picked up a set of 18" apex wheels with Hankook RS4s 275/35/18 squared (4-5/32nds and 5yrs old). They are tramlining all over the place with the crappy roads here in Boston.
Would I experience less tramlining if I moved to the same size in PS4S or would it not make any difference?
2013 e92 M3
2011 X5 35d
2018 F80 M3 ZCP
      04-02-2021, 08:27 PM   #2
MaAl
MaAl's Avatar
72
Drives: 2011 E92 M3 ZCP
The square setup along with your alignment are gonna lead to tramlining the most. If you're gonna swap over to PS4S id add an alignment with some toe in to help mitigate it.
DL335D580.00
      04-02-2021, 10:31 PM   #3
DL335D
DL335D's Avatar
580
I'm at -1.5 and 0 toe front.
I'm going to check my tire pressure too. I'm 35 pounds at each corner. I'll lower them to 32 and see if that helps a bit.
2013 e92 M3
2011 X5 35d
2018 F80 M3 ZCP
      04-02-2021, 10:54 PM   #4
tdott
Drives: M3
It's the zero toe in front.
Add some toe in, and it won't be as bad. But wider tires are going to tremline and follow grooves more than stock.
      04-03-2021, 12:18 AM   #5
CPWINCH
CPWINCH's Avatar
Drives: Toyota Prius
its having 275s up front. Ive gone up to 295 and it only gets worse lol. You will get used to it
Also throw those tires out asap, wouldn't recommend driving on 5+ year old tires
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
DL335D580.00
      04-03-2021, 12:25 AM   #6
Redd
I ran zero front toe on 255 tires and tramline like crazy. Add just a wee bit of toe in.
      04-03-2021, 12:35 AM   #7
SAMM3Y
SAMM3Y's Avatar
3085
Drives: 2008 m3
Gotta beef up for wrestling the 275's.... three protein shakes a day, shake them outside the car...
9ers
Appreciate 6
DL335D580.00
shimmy232350.00
Shrike360475.50
slcook541863.00
      04-03-2021, 10:12 AM   #8
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
I ran a square 275s on my daily and eventually sold them. It got too dangerous and I hated being so white knuckled on the Seattle freeways
      04-03-2021, 11:32 AM   #9
Shrike360
Drives: 2009 E92 M3, 2011 Porsche CTT
My first M3 I ran 275 square and had a similar issue with tramlining. Current car I'm running a 275/285 setup, and that actually seems to help a little. Still can be a problem on some of the most rutted freeways around here, but in general it feels better.
      04-03-2021, 01:51 PM   #10
CPWINCH
CPWINCH's Avatar
White knuckled highway driving? How fucking bad are you at driving?
      04-03-2021, 02:01 PM   #11
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
Come up to Washington and experience our lovely highways when it's raining.
      04-03-2021, 02:08 PM   #12
SAMM3Y
SAMM3Y's Avatar
3085
Drives: 2008 m3
One of the roads I travel the most is a main artery through the city that the county semi trucks use to cut through instead of going around on the freeway. They've ruined the road.. the tram lining is horrid on my car with a 275 front but as others have mentioned a touch of front toe helps a lot. I added a little rear toe in on mine recently too.
9ers
      04-03-2021, 07:19 PM   #13
CPWINCH
CPWINCH's Avatar
ooof you make a good point. I forget not everyone lives in a desert climate
      04-03-2021, 07:53 PM   #14
pbonsalb
I run 265/35/18 (with 285/35/18 or 295/35/18 or 285/30/18 rears) and don’t tramline. One set of PSS and several sets of EC Sport.
      04-09-2021, 09:35 PM   #15
DL335D
DL335D's Avatar
580
How much toe should I tell the alignment shop to add?
2013 e92 M3
2011 X5 35d
2018 F80 M3 ZCP
      04-10-2021, 10:42 AM   #16
Redd
They added just a little bit - 3 minutes of toe in each side.
DL335D580.00
