03-01-2023, 02:58 PM | #1 |
Rep 490
Diff making noise?
I took my M3 as there's a crunching sound from the back when I turn that is new. They suggest replacing the diff fluid. Does this make sense?
Concern Critical Customer States When He Makes Angled Turns At A Slow Speed Rear End Makes Crunching Noise Cause WHEN THE REAR WHEEL SPEED DIFFERENTIAL VARIES DURING TIGHT CORNERING, A SLIP/STICK EFFECT IS CREATED ON THE LINING AND STEEL DISCS INCORPORATED IN THE DIFFERENTIAL LOCKING CLUTCH CAUSES A GRINDING NOISE. THIS NOISE TYPICALLY GOES AWAY AS THE LOCKING CLUTCH DISCS IN THE DIFFERENTIAL WEAR IN. THE BREAK-IN TIME VARIES DEPENDING ON DRIVING HABITS; FOR EXAMPLE, TIGHTER CORNERING (WORKING THE LOCKING CLUTCH) MEANS THAT IT TAKES LESS TIME TO WEAR IN THE LOCKING CLUTCH DISCS. Correction PERFORM DIFFERENTIAL FLUID EXCHANGE Estimate $ 770.07
2013 M3 LMB, DCT, ZCP, Premium, EPS, Bamboo Beige, Apps, sunroof
03-01-2023, 03:10 PM | #2 |
Rep 398
The BMW SAF-XJ + FM Booster formula should be the most common/preferred way to cure this issue.
The $700+ quotation, however, is pure highway robbery.
IG @ddddrmmm
spammysammich1583.50 Theodore668.50 |
03-02-2023, 01:53 PM | #3 |
Rep 7,110
Change the fluid yourself OP. Castrol Syntrax Limited Slip 75w-140. What BMW are selling but apparently a tad less FM. Easiest DIY there is assuming you have a lift around.
Ps. Made less grinding noise in my diff then the OE coming out, very rewarding. |
DukeofAlexandria633.00 spammysammich1583.50 |
03-02-2023, 02:18 PM | #4 | |
Rep 510
-Duke |
03-02-2023, 02:34 PM | #5 |
Rep 1,104
fcpeuro sells a conveniently put together kit for servicing the diff that includes fresh drain and fill plugs as well. Easy as pie. Crack the fill plug first.
DukeofAlexandria633.00 B18c jdmgsr71.00 |
03-03-2023, 03:34 PM | #6 |
Rep 490
Thanks all for input. I gave dealer the OK to perform the diff fluid change. Only other thing I saw on this forum is where a member had a similar rubbing sound in the back and it was a bad carrier bearing.
I'll see if this clears it up.
