08-20-2018, 02:21 PM | #1 |
Merlin
474
Rep 730
Drives: 2012 BMW M3 6MT w/ZCP
What does the throttle Sport, Sport Plus really do ?
Greetings,
Ok, before I torched for not looking or searching for this I did - But found nothing So when you enable the Sport and Sport Plus mode of the throttle, what does it do ? I get it likely changes the throttle map logarithmically - I think ? It makes the pedal response way, way to jumpy and jerky at low speeds or starting from full stop. But, if I can launch properly the Sport Plus mode seems to make my rear tires slip and smoke up - which is possibly not a bad thing. Any experts on this ? Thanks in advance
2012 E92 M3 ZCP | 2008 E90 335xi | 2008 E90 335i | |
08-20-2018, 09:11 PM | #2 |
Rep 184
I guess you are asking if they are using specific algorithm for the throttle mapping? I do not think there is just one algorithm in place. My thinking is that they define mapping specifically for each mode for each gear to change the way it feels when we drive it. Take a look here - if I'm reading it right as the result engine torque line is different for each gear in different modes.
08-20-2018, 09:52 PM | #3 |
Rep 1,055
My undersrtanding is that each level requires less pedal input to give you more throttle response as you progress from regular to sport plus. This is consistent with what I experience.
It's been covered several times: https://www.m3post.com/forums/showthread.php?t=312863 https://www.m3post.com/forums/showthread.php?t=174191 https://www.m3post.com/forums/showthread.php?t=530573 Last edited by M43S7RO; 08-20-2018 at 10:03 PM.. |
08-20-2018, 09:57 PM | #4 |
Rep 12,726
It just increases throttle response by increasing throttle position sensitivity. It doesn't add any power whatsoever. For example, what normally would be 40% throttle would be 70% throttle with the "power" button on.
08-21-2018, 08:27 AM | #5 |
Rep 1,663
The sport+ throttle option is awful. It just gives it an overly aggressive map which makes it hard to modulate. I find comfort a bit lazy for spirited driving with too much dead space in the middle, sport is a nice center ground and feels the most linear (linear is good!), sport+ is a mess.
For the M2 its even worse, comfort / sport / sport+ throttle are not individually configurable. So for example on the M2 you cant have Sport Throttle, Sport steering, MDM mode. For MDM you have to be in Sport+. BMW really cheaped out there. |
08-21-2018, 10:02 AM | #6 | |
Rep 591
such a misleading button label... |
08-21-2018, 10:44 AM | #7 |
Rep 270
Drives: Red
I can't stand the default throttle behavior, you practically have to fully floor it to get the car to do anything. I was very excited to find you can set it to start up in sport as pressing the button every time gets old.
Iyzmi802.00 |
08-21-2018, 03:22 PM | #9 |
e90noob
1588
Rep 1,862
i must have changed the M mode to include Sport plus throttle...
it's great if i'm just stomping on the gas but if i'm just trying to semi-accelerate, the car gets jerky and doesn't like it definitely going to change the settings and see how i like the other options
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 |
08-21-2018, 09:06 PM | #10 |
Lord Scrip
1812
Rep 3,013
Drives: 2011 M3 Coupe
Sport plus throttle is awesome! It's the worst in traffic but when you wanna play, no other setting should be considered. It's sad when sport plus no longer scares you and you want more. The feeling of "this feels jerky" is a lack of user input and not a shortcoming of the cars programing or equipment.
08-22-2018, 02:22 AM | #11 | |
Driver
2692
Rep 2,714
Normal -> Sport -> Sport+ -> on/off switch |
08-22-2018, 07:13 AM | #12 | ||
drunk poster
6613
Rep 3,649
