04-09-2024, 12:09 AM | #1 |
Rep 73
Infamous Post Liquimoly Oil Change Tick
As the title suggests I recently performed my second oil change since owning the car. The first oil change was done at EAS when the rod bearings were replaced, and they used Castrol. The second oil change was performed by myself, switching from Castrol to Liquimoly. (10W60 if it wasn't already assumed). After completing the oil change and inspecting the filter I noticed a small amount of metal bits (shavings? - not sure how to classify them) in between some of the filter fins. I'm not overly concerned, but am also wondering what it could possibly be. Possibly related possibly not, and to bring this post back to the main topic I noticed an intermittent ticking sound after driving my car roughly 50 miles this weekend on a spirited canyon drive. The car has now only done about 100 miles or so after the oil change, and I am hearing that same sound that others have described in many threads.. usually after performing an oil change and more specifically changing to or using Liquimoly. Just like others have experienced, the sound is intermittent with no true rhythm, and it is best heard near or behind the driver's front wheel. Tomorrow I will post pictures of my filter from the last oil change, and if anyone can chime in on the ticking noise I'd love to hear some opinions.
https://www.m3post.com/forums/showthread.php?t=1167323 Went through this whole thread last night if anyone wants to see some other examples/discussions. Also, I want to be clear I am in no way shape or form trying to bring down Liquimoly, I love their products and the engine seems to run better than ever after the change, I'm simply curious and a little concerned as to what may or may not be happening to my engine. |
04-09-2024, 11:44 AM | #2 |
Rep 1,710
if you're concerned, do another oil change to make sure you flushed out any other metal shavings.
^ probably best to do that. LiquidMoly isn't that great and compared to other equivalent oil.. it introduces the most engine noise lol also factor in the colder than usual climate here in SoCal right now.. personal experience. no valve tick on these oils I've tried below: Redline Motul 300V Amsoil
04-09-2024, 11:48 AM | #3 |
Rep 140
Unfortunately the shop that did my bearings used liquimoly. I’ve used motul 8100 10w60 for my past 2 changes and it’s nice and quiet.
sergbaja5t61.50 LMBE9263.50 |
04-09-2024, 02:27 PM | #4 | |
Rep 81
04-09-2024, 04:33 PM | #5 | |
Rep 1,710
could be excess still in the oil cooler. then let it idle for a bit and then change your oil with your preferred brand.
04-09-2024, 04:52 PM | #6 |
Rep 561
I don't get the hype for Liquimoly in the BMW world. It gets laughed at on BITOG. The shop that did my bearings wanted to use it. Had em switch to Redline 5W50 instead. Especially for Chicago winters, also since I did them during the coldest part of this winter lol.
If you're concerned about shavings I'd dump and replace with Castrol or Redline/Motul. Not worth taking the chance. |
04-09-2024, 09:00 PM | #7 |
Rep 164
Ditch that junk ass liquimoly. I used that garbage in my motorcycle years ago and hated the shifting feel. Needless to say, I drained the oil after 500 miles and switched to Motul 300V/ 7100, & Redline.
Last year I did 3 or 4 oil changes using liquimoly and would consistently burn through 2 quarts of oil during a 5000 mile period. Now using Motul 8100, and have to top up a quart of oil after 3.5K-4K miles. |
04-09-2024, 09:51 PM | #8 |
Rep 151
Drives: 2013 M3: E92, ZCP, DCT
Throwing my 2 cents in: currently using, and like, Redline 10W60. No problems so far.
-Mike M.
2013 M3 [E92, Alpine White, ZCP, DCT] 2016 i3 REx [Tera World, Capparis White] |
04-09-2024, 11:20 PM | #9 | |
Rep 73
04-09-2024, 11:22 PM | #10 |
Rep 73
@E92Bean I purchased the Motul 8100 today and it should be here before the weekend. Looking forward to changing the oil with the Motul kit. I greatly appreciate your reply!
04-09-2024, 11:25 PM | #11 | |
Rep 73
04-09-2024, 11:26 PM | #12 | |
Rep 73
04-09-2024, 11:28 PM | #13 | |
Rep 73
04-09-2024, 11:29 PM | #14 |
Rep 73
04-09-2024, 11:33 PM | #15 |
Rep 73
After the rod bearings were replaced I never really took a good look at the old ones. At the time I basically just pulled one out and said ehh not too bad. But tonight I inspected each one pretty thoroughly and my opinion is for 140K they're not too bad as I've definitely seen worse, but in certain spots I can start to see slivers of copper and I'm definitely glad I had the originals replaced.
04-09-2024, 11:36 PM | #16 |
Rep 73
I also took a better look inside the filter. The left bigger chunk seems to be valve cover coating to me. I'm not overly concerned about that however there are multiple examples within the filter fins that look very similar to the metal piece on the right. The oil filter is not filled with these flakes but it's definitely more than I'm comfortable with.
04-10-2024, 12:12 AM | #17 |
Rep 140
Nice, FCP kit is solid. I know many people experiment, but I don’t see myself trying any other oils.
04-10-2024, 12:34 AM | #18 | |
Rep 1,710
04-10-2024, 12:38 AM | #19 | ||
1925
Rep 1,894
04-10-2024, 12:52 AM | #20 | |
1925
Rep 1,894
The hype is that it's almost $50 cheaper than the next cheapest option per oil change. It's a good oil for the price, but no one is saying it's the best thing ever. My oil change interval is every other track weekend or about 2500 miles and differential fluid every other year. With these low change intervals, I've had no issues or indications of oil consumption with LM's 10W60 or their differential fluid.
