04-26-2013, 01:56 PM | #1 |
Rep 229
19x10 359 wheels on stock edc suspension
I hace just purchased a set of the ZCP 359 wheel 19x10 et 25 all 4. I will be putting these on my 2011 M3 stock EDC suspension but I was curious if anyone can help me with rubbing issues on this or not??? . I am going to run the Michelin ps2 front 265-35 19 and rear 275-35-19 but I am worried about rubbing.
04-26-2013, 02:24 PM | #4 |
11817
Rep 23,187
Rear should work either way but I would just go 265-30 on all 4 then you can rotate around for better wear and it dials out a bit of the understeer character that is part of the car stock.
04-26-2013, 02:30 PM | #5 |
Rep 229
Ya I just got confirmation on this.. Looks like IM going to go with the 19x9 front et 18 and 19x10 et 25 and run a 5-10 mm spacer on the rear depending on how she looks first off. Tires will be 255-35-19 and 285-35-19 Im looking at
04-26-2013, 05:33 PM | #8 |
Rep 229
265 on a 19x10? Idk dosent that get into the stretched look? Would you all rather go with the 19x10 Square setup or stick with the regular ZCP 19x9 and 19x10? with the 255 35 and 285 35?
04-26-2013, 05:47 PM | #10 |
Rep 229
It will work dont get me wrong But depending on tire brand it might seem stretched to some. 265 is definitely the lowest you would want on a 10 inch rim.
04-26-2013, 08:45 PM | #11 |
Rep 81
There are quite a few who went 275/30/19 on the square setup with 359Ms (rears all around). Seems to work well with no rubbing and what I'm leaning toward at the moment...
Here is an example of the configuration using Nitto NT555s: http://www.m3post.com/forums/showpos...8&postcount=20 |
04-28-2013, 02:47 PM | #12 |
Comrade
56
Rep 211
Drives: 15 M4 DCT
i have same wheels 19x10 all around with 275/30 front and 295/30 rear pilot super sports on a non zcp car and i have no rubbing just my two cents
15 M4 / 14 M235i-Sold / 09 E92 M3-Sold / 07 E92 335i-Sold
04-28-2013, 02:52 PM | #13 |
Rep 1,128
Drives: 2013 E92 M3, 2016 X5 50i
I'm running 265/30/19 front and 295/30/19 Rear no issues at all!!!
I Am The Strength Behind The Fight!
