04-28-2023, 07:34 AM | #1 |
Rep 146
ESS VT2-625 Injector Question
Hey all,
So it seems like my "White" top injectors off the 625 kit are leaking. Looked up the direct part number associated with these injectors, but I'm not sure if they're modified any differently from what ESS provides aside from the machining work. Does anyone know if the OE replacements online would fit with a fuel spacer? |
04-28-2023, 11:01 AM | #2 |
Rep 10,614
I doubt ESS modified the injectors but do not know for sure. Can you see any signs of modification from what you can see of an injector?
04-28-2023, 11:17 AM | #3 |
Rep 146
Judging from the photos online associated with this part number it looks like the nozzle plastic/area has been modified for the ESS version. More concerned of whether or not these will fit as a direct replacement as ESS has done away with these injectors and replaced them with a blue/black injector?
05-03-2023, 07:43 AM | #5 |
wannabe
252
Rep 819
Find a local shop that offers injector servicing/cleaning. They should be able to clean/service your current injectors and should also be able to provide you with a suitable replacement if the injector is indeed damaged.
E90 M3 - 6speed - slicktop - single hump
DrFerry6728.50 |
05-03-2023, 10:50 AM | #6 | |
Rep 146
As a test I took the injectors out tied each one in a zip-lock bag and saw a few of them were "dripping" overnight. |
CamasM3e933152.00 DrFerry6728.50 |
05-03-2023, 01:21 PM | #7 | |
Rep 77
DrFerry6728.50 |
05-16-2023, 11:33 AM | #8 |
Rep 146
Incase anyone was curious about replacement injectors for their ESS-625 kit - ended up ordering Bosch 0280158124 (Black Injectors) as a direct replacement since the white ones are extremely outdated.
Works and performs as it should with no spacers/additional accessories. Much cheaper to source them as supposed to buying from ESS directly. |
DrFerry6728.50 |
05-16-2023, 04:51 PM | #9 |
Rep 1,195
Thanks for the info, I know those black ones are the standard ones now sold on the G kits. Do you happen to know if it’s the same flow rate as the whites?
2009 BMW 335i 6MT
*big single (eventually)* For now... MHD tuned VRSF Race IC DCI ATM exhaust |
05-16-2023, 05:33 PM | #10 |
Rep 146
06-29-2023, 10:06 AM | #11 |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
Did you flash an updated version of the ESS software?
06-29-2023, 10:28 AM | #13 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
https://www.bpmsport.com/e9x-m3-supe...injectors.html .
///M Power-Belgium63331.00 omgzirra_exe1481.00 |
06-29-2023, 11:00 AM | #14 | |
Rep 1,696
DrFerry6728.50 |
06-29-2023, 03:13 PM | #15 |
Rep 21
06-30-2023, 05:21 AM | #17 |
mTekMods
2142
Rep 2,902
change your hobbs switch to honeywell
omgzirra_exe1481.00 CurbBender'9071.50 |
06-30-2023, 06:25 PM | #18 | |
Rep 132
DrFerry6728.50 |
06-30-2023, 10:49 PM | #19 |
Rep 1,696
he does though? lol
07-01-2023, 02:36 PM | #20 |
Rep 132
07-01-2023, 03:42 PM | #21 |
Rep 1,696
its literally on his website, and yes the flex kit makes it safer and easier as e85 isn't consistent from pump. so it helps. sure you could run it straight, but you'll be maxing your duty cycle which is not good for you.
07-01-2023, 05:46 PM | #22 |
Rep 132
I can see it’s on his website. There’s tons of people that have tried to get an actual e85 tune including myself from Mike and he is unable or unwilling to do so. Why offer a product yet not stand behind that product at all and steer people to a 93 tune with a flex fuel kit is completely laughable. Your last point doesn’t make any sense. You will max out duty cycle regardless if you run a e85 tune or a flex fuel kit if your injectors do not flow enough.
