11-14-2014, 05:22 AM | #1 |
Rep 28
Question on fitting new wheels
Hi, had a call from UPS and my New wheels should be arriving today
I've gone for Apex Arc-8 10x18 ET25 in Gloss Black, Tyres are Pilot sport Cups 285/35/18 squared, i plan on running a 10mm spacer up front and a 5mm spacer in the rear Is there other special requirements to make them fit or should they go straight on no problems? Thanks for your time |
11-14-2014, 09:27 AM | #2 |
Rep 536
If you have a drop? Then your going to have problems in the front!
You don't need spacers for the front because it's already wide as it is w/that setup. Your going to have to do some camber adjustments to tuck the fronts in. |
11-14-2014, 06:16 PM | #3 |
Rep 6,735
You will need at least -3 front camber for a tire that size.
'23 X7
11-16-2014, 06:17 PM | #4 |
Rep 28
Hi thanks for the reply i should of said i will be running club sort 3 way KW's with 3deg camber up front and 2.5 in the rear.
is there an arch mod or something that needs doing or is it a straight fit with the above mentioned many thanks |
