05-28-2019, 11:26 AM | #1 |
Rep 1,074
unplugging EDC after coilover instal
hi guys just installed some KW V3;s and want to make sure im doing the right thing with the EDC. i will be getting it coded out, so do i just unplug each sensor from shock and put them away. is there another module or anything that needs to be unplugged before i code it out. thank you
05-28-2019, 11:38 AM | #2 |
Rep 615
You don't need to remove the sensors. Just leave them where they are, they just won't be plugged into the new shocks. You don't need to do anything with the modules, if you are going to code EDC out.
05-28-2019, 05:32 PM | #4 |
Rep 1,074
That’s the one in the boot yeah?
That’s why I’m asking. I left it plugged in. Do I HAVE TO disconnect it or will it be ok coding edc off while it’s plugged in? Just saving myself taking boot trim out again unless I 100% have to. |
05-30-2019, 03:34 PM | #5 | |
Rep 1,122
edit: Now that I'm thinking about it I may have read that they moved the location of the module in the MY 2011+ cars |
05-30-2019, 04:07 PM | #6 | |
Rep 3,982
Unplugged left no lights or warnings after coding. |
05-30-2019, 07:16 PM | #7 |
Rep 1,074
06-03-2019, 10:27 AM | #8 |
Rep 265
06-14-2019, 10:17 AM | #9 |
Derbo Tuning
3607
Rep 3,022
EDC module in the trunk needs to be unplugged. In the vehicle order, you delete the EDC VO $233 and write FA to CAS and NFRM.
In the KOMBI, set EDCK_ALIVE_ZAEHLER | EDCK_ID_MONITOR to nicht_aktiv In the CIC , set EDC_CIC nicht_aktiv Why pay for a module when this is far cheaper and removes EDC from the menus? Even coding someone will be cheaper than buying these units.
IG:ruhrohz_m3
05-17-2021, 09:57 AM | #10 | |
Rep 210
Also when I got my car back my comfort access stopped working don't know if this is somehow related? Sorry reviving an old thread |
05-17-2021, 06:46 PM | #11 | ||
Astronaut
514
Rep 732
As far as the comfort access issue goes, it probably needs to be recoded.
Instagram | @undisclosedm3
"Never think that you are above taking out the trash." |
05-24-2021, 01:42 PM | #12 | |||
Rep 210
In the picture it's the cable in between the blue and black connectors. TIA |
05-24-2021, 03:45 PM | #13 | |
Derbo Tuning
3607
Rep 3,022
IG:ruhrohz_m3
