06-03-2017, 12:39 PM | #1 |
Stop the hate, get a V8
3850
Rep 8,625
Help me pick a paint coating
Frankly, I am a bit overwhelmed with the choices for these paint coatings (Opticoat, Modesta, Cquartz, etc). I am planning to get the front sections of the car covered with Xpel Ultimate to protect against rocks and such, and the whole car will get the coating including the wheels.
Some background that might help: Car isn't daily driven It sits in a garage most of the time, out of the elements. Car doesn't see snow I store it November 1 to April 1. I live in downtown Chicago It can be difficult to wash the car often and thoroughly, but I do use quick detailer whenever I can. Waxing and more involved cleaning is tricky (I basically have to drive out to my parents' house to do it). I track the car The car gets pretty dirty at the track from pieces of tire and other dirt that are flung up at it. Historically those have been a real bitch to clean. The factory Admiral Blue paint is vibrant In bright sunlight, it really pops and looks great. I'd like to balance price and protection The Xpel Ultimate is going to be over $2k just for the front half of the car, so I'd like to find a coating that's reasonably priced. One installer said I could probably get away with more of a mid-grade coating since the car doesn't get exposed to the elements and extreme conditions, and it will probably last a pretty long time as a result. His suggestion was Cquartz Finest instead of Modesta or Opticoat. I saw it on a Sakhir Orange F80 M3 in their shop and it looked amazing. I talked to another installer and he suggested the Modesta BC-04, but also said I could probably do BC-05 if I want a bit more gloss at the expense of durability. I saw the BC-04 on a customer's CTS-V and it looked good, but not as "wet" as the Cquartz Finest. Cquartz seems to have more nods than the Modesta when I look around on various forums (both for detailing and various cars). I don't need to see photos or anecdotal "I have X and I like it", I'd like to hear the more objective discussion about why one coating over another. Thanks in advance!
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 06-03-2017 at 01:58 PM.. |
06-03-2017, 03:17 PM | #2 |
Rep 1,256
Is the paint being corrected first? Coatings and wax really don't change the look period, once the paint is corrected. Just pick which ever one lasts the longest. Coatings and wax are protection, not for looks
Opti-Coat Pro is a good choice.
06-03-2017, 03:25 PM | #3 | |
3850
Rep 8,625
Yes, all of these shops do paint correction first. The car only has 1650 miles so it won't need much.
Past: 2011.5 M3 sedan ZCP |
06-03-2017, 03:25 PM | #4 |
Rep 1,256
Perfect. Pick the longest lasting! If they offer Opti-Coat pro, go for it!
06-03-2017, 03:28 PM | #5 |
3850
Rep 8,625
Why do you recommend Opticoat?
06-12-2017, 04:47 PM | #7 |
Rep 364
Where in Chicago are you going? I'm going to seek out paint protection and correction after I get my bumpers re-sprayed. I'd like a solid recommendation.
06-12-2017, 04:52 PM | #8 | |
3850
Rep 8,625
Either Chicago Auto Pros or Auto Image. I visited both in person. Specifically, I asked if they had wrapped a Z06/Grand Sport since it has some very unusual styling elements that are not considered "easy" for wrapping -- and yes, both had experience with my car. Both are also right by the Metra stations so it'd be easy to head back downtown while they have it for a few days. FYI they will do paint correction before applying the film and/or any sort of ceramic coating.
06-13-2017, 09:54 PM | #9 |
Rep 2,907
Drives: 2011 E93 M3
I used a lot of Cquartz when I was doing corrections on exotics...Laborious to apply well but results were always fantastic. I've been using GTechniq on my own cars these days- easier and looks just as good.
07-07-2017, 10:25 AM | #10 |
Rep 3,988
I have BC-04 on mine, it's only been 3 months, so can't really comment on durability yet. It's also the only coating I've ever done so not much to compare it to. It's definitely a higher end coating, not any ma and pa shop can get their hands on it.
Did a track day 2 weeks ago, washed the car the next day and most of the rubber marks came off super easy with soap and water. Some required a little more pressure to get off, but nothing compared to when I had no coating which required a hard scrub then compounding after, it was a bitch to remove those marks before.
07-08-2017, 10:28 AM | #13 |
Rep 995
I've used opti coat, cquartz and currently have gtechniq with exo. I'd say go with gtechniq or cquartz. They give the paint a deeper finish and have lasted longer than opti coat.
07-08-2017, 11:53 AM | #14 | |
Rep 1,256
https://www.amazon.com/Mothers-09224...rubber+remover
07-08-2017, 02:18 PM | #15 |
Rep 1,216
I'm getting CQuartz on mine July 25th. I've done a bit of reading my self and it's hard to determine one vs another. The guy locally doing mine said CQuartz is his more chosen coating over anything else he does. So going with the crowd favorite locally
2011.5 E90 M3
LeMans Blue |
07-10-2017, 09:16 AM | #16 |
3850
Rep 8,625
I decided on CQuartz Professional. The car is going in tomorrow for the paint prep, Xpel, and coating. I'll post some photos once it's all done!
07-12-2017, 07:20 PM | #17 |
Rep 6,916
just a suggestion, why not film more with your budget for the coating, I think coatings are great we install a lot of it, but what I tell my customers if you truly want the best protection against rock chips and swirls etc, wrap as much as you can afford.
since you did mention it's not daily driven picking up a silica based sealant would be more than enough till you figure out which coating to go with... hope that helps a little |
