07-24-2020, 05:42 AM | #1 |
Rep 108
How often your ABS sensors fail if the car is tracked?
Hi
This happened on track yesterday. Braked hard after the main straight, before U-turn. Didn't notice ABS light, which came on during main straight, I believe. ABS malfunctioned and Proxes R888R were done. Front camber is 2.5, if you wonder. I just replaced two rear ABS sensors during last month (they failed in 2 week period) and now Carly tells that front left is done! Do you guys replace tehm routinely, before failing?
M3 E92 ZCP LCI
07-27-2020, 01:45 PM | #2 |
///M Powered for Life
11483
Rep 10,329
Mine have never failed, front or rear, in either of my M track cars
Which bbk are you running? You may just be melting them. |
07-27-2020, 07:22 PM | #3 |
Rep 1,617
Failed on my car once, about 2 years ago. It looked like the sensor got rubbed by a tire or suspension parts. They haven't been damaged since we replaced and ziptied it in a secure spot, away from movement.
07-27-2020, 09:47 PM | #4 |
Rep 957
All four of mine failed pretty close in time. It was between 7 and 8 years old iirc. I've only tracked it a handful of times.
2011 e92 ///m3 zcp - jzb/fr
ED 6/29/10 |
07-28-2020, 03:15 AM | #5 |
Rep 108
Thanks, this correlates with my case. Three sensors failed in short time, my car is 9 yrs old though.
M3 E92 ZCP LCI
07-28-2020, 03:17 AM | #6 | |
Rep 108
details here: https://www.expressivedrives.com/blog/f8x-brakes-to-f9x
M3 E92 ZCP LCI
